Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 06-02-2013, 17:57
Roboto Roboto is offline
FRC #3151
Roboto is an unknown quantity at this point
Post Some programming help on compressors and cylinder pressure
Programmer here. My team wants to have an on board compressor on the robot this year that turns on when the pressure in the tanks in x and shuts off at y pressure. We can can figure out how to turn it off and on. But any help or insights as to how we can get it to turn off/on at certain pressures would be most appreciated.
Unread 06-02-2013, 19:18
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Some programming help on compressors and cylinder pressure
As long as you have the pressure switch attached to the high side of your system, it will automatically turn itself off and on when it reaches 120 PSI. Make sure you have the switch wired between the signal and ground pins on Digital Input 1 (the default input for the code).
I'm right 90% of the time, so why worry about the other 3%?
Unread 06-02-2013, 22:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You'll need to Open the compressor in Begin, then Start it, then Set its RefNum with a handy name such as "Compressor". In Periodic Tasks there's already a bit of code that runs the Compressor Control Loop; you just need to enable it and make sure the RefNum Get name matches what you gave it in Begin.
The Compressor functions are in the WPI Robotics Library >> Actuators >> Compressor function subpalette.
