Go to Post i'm not addicted to CD.com...i can stop anytime i want. - RogerR [more]
Unread 06-02-2013, 19:26
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
Trouble updating the latest Driver Station 2013
Hi!
Frank just posted on the FRC blog (http://www.usfirst.org/roboticsprogr...s-m1013-camera) that there is a manditory Driver Station update. I downloaded it and tried to install, but when I do, an error pops up:
If I click "Yes", another error that says basically the same thing (but different file name) pops up.
Anyone else having this problem? Or, does anyone have a solution?
I should say that I have 2 HDDs in my computer and the Labview program is installed on the secondary HDD, NOT the OS drive. This all works, I do it with 90% of my programs and no errors with any of them.
Unread 07-02-2013, 01:51
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
Rookie Year: 2012
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
Re: Trouble updating the latest Driver Station 2013
Have you extracted all of the files and folders from the ZIP file onto your hard drive? If you try to run the setup.exe from within the compressed folders, it will fail.
Unread 07-02-2013, 08:49
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
I did unzip them before. I unzipped them again just to be sure, and it still showed the same error.
Unread 07-02-2013, 12:46
markmcgary's Avatar
Software Mentor
Rookie Year: 2012
I know this sounds obvious, but Windows makes a 'compressed' folder look very much like a 'real' folder on your PC. It's easy to think that you are running 'setup.exe' from a 'real' folder when it is actually still the 'compressed' folder. I've made this mistake before.
After extracting the files from the ZIP, make sure that you navigate to the 'real' folder where the files were extracted and run the 'setup.exe' from the 'real' folder and not the 'compressed' folder.
Another possibility is that the entire folder structure was not extracted from the ZIP. There are subfolders in the ZIP that must exist in the 'real' folder after extracting all of the files.
If you are running 'setup.exe' from the real folder and have extracted all of the subfolders correctly, then I have no idea what the real problem may be. We will be running the update this afternoon and will see what happens.
Unread 07-02-2013, 12:51
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Wow! Strangely enough I tried something similar to what markmcgary said. I tried re-extracting it, but our team uses Google Drive to share stuff and, previously, I extracted it on the GDrive, but this time I just extracted it to the desktop AND I un-checked the "Check updates" box at the beginning (not sure if that did anything :-/ )
So, in a nut shell: extract the files to a physical place, not cloud storage (for some reason).
Thanks for the help everyone!
Unread 07-02-2013, 12:54
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Thanks, but I just fixed the issue. Read my last post :-)
