Go to Post Eventually, the "less effective" tweaks will settle to the bottom, and the more effective ones will be assimilated by the group. Then someone will tweak the tweak. That's when the fun begins. - Billfred [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 06-02-2013, 23:12
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Bonding polycarbonate to polycarbonate
Hi everyone,
Does anyone have experience bonding polycarbonate to itself? I have tried thick CA (superglue) and this stuff called SCIGRIP 16 which I was told was recommended by the guy at the counter at TAP Plastics. The thick CA is pretty lousy, and the SCIGRIP 16 works alright, but I was wondering if anyone could recommend a better option...
Thanks!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 06-02-2013, 23:15
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Bonding polycarbonate to polycarbonate
As it would turn out, loctite sells a polycarb adhesive readily available at a local Walmart. I'll get the exact name tomorrow when I have the tube in hand. Works great, dries in five minutes, sets in an hour and cures over night.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 06-02-2013, 23:23
dsherw00d dsherw00d is offline
FRC #0378
dsherw00d is a jewel in the roughdsherw00d is a jewel in the roughdsherw00d is a jewel in the rough
Is it this stuff:
http://www.loctiteproducts.com/p/13/...tic-Bonder.htm
I'm interested as well and didn't know they made a product that could work.
Unread 06-02-2013, 23:43
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Rookie Year: 2007
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Might want to try to get in contact with someone from 1714 MORE robotics. They make their entire robot out of the stuff.
Unread 06-02-2013, 23:50
Ian, I've used this stuff for projects at home as well as the Loctite one, both work exceptionally well. Both this and the Loctite require the applicator gun.
http://www.walmart.com/ip/Devcon-Pla...er-ii/15632453
Use: http://www.youtube.com/watch?v=AHMykiX_YEQ
Unread 07-02-2013, 00:04
CalTran's Avatar
Missouri S&T Senior
Rookie Year: 2010
Yeah, I think it was the epoxy plastic bonder. I didn't know that an applicator gun was necessary. Our team usually just squeezes our epoxy out onto a plate and use a spoon or fork or pop-sicle stick to mix the stuff. I think the plastic bonder actually came with an applicator stick though.
Unread 07-02-2013, 00:24
Best Available Data
That mixer gun is genius. Having taught many people to use epoxy, I've had plenty of people tell me that "that stuff is garbage! doesn't stick at all!"
Does it dry fairly clear? Being a see-through structure I have been fretting over how to make the joints not look like garbage. I've asked Pinecone as well, will report back what he recommends being from the land of plastic.
Unread 07-02-2013, 01:18
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
Another option is to heat the sheet with an acetylene torch and bend it on a vice. My team used this method on our robot last year for one of our components. Although this only really works for certain applications. If you don't need absolute precision, then this is a great way to go.
Stevens Institute of Technology
B.A - Electrical Engineering 14'
Mentor - FRC 714 (2012-Present)
Student - FRC 714 (2009-2010)
2013 Bridgewater-Raritan Winners (Thanks 1676 & 3314)
2012 MAR Regional Championship Judges Award
2012 Mount Olive District Excellence in Engineering Award
2012 Chesapeake Regional Finalist (Thanks 2068 & 358)
2012 Hatsboro-Horsham District Gracious Professionalism Award
Unread 07-02-2013, 06:32
protoserge's Avatar
protoserge protoserge is online now
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
The Loctite plastic bonder doesn't work well for polycarbonate sheets in my experience.
You want Methylene Chloride. It can be expensive, but you don't need a lot to make the bond. You will need a syringe to put drops of material along the surfaces to bond.
http://www.ehow.com/how_5686551_glue...ate-sheet.html
http://www.ehow.com/how_6635889_glue-lexan.html
http://www.mcmaster.com/#catalog/119/2120/=ldfxxn would need some additional chemicals added to the mix to make it easier to work with.
I've had experience with Weld-On #3 such as this: http://www.eplastics.com/Lexan_Polycarbonate_Glue
Unread 07-02-2013, 07:22
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
A lot of very good information about using polycarbonate can be found here: http://www.curbellplastics.com/techn...e-makrolon.pdf
They have all sorts of information about bending, heating, forming, gluing, melting, folding, spindling, mutilating, and abusing polycarb.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 07-02-2013, 07:28
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
I've had experience with Weld-On such as this: http://www.eplastics.com/Lexan_Polycarbonate_Glue
Methyl chloride works great, but it's really nasty stuff. I wouldn't reccomend using it without proper ventilation and personal protestive equipment, such as a respirator. Read up on exposure to it before considering using it.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 07-02-2013, 08:59
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
I would also second methyl ethyl ketone/Methyl chloride.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 07-02-2013, 11:41
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
I would strongly suggest reconsidering MEK and Methylene Chloride unless you have a really well ventilated area to work in and respirators to use.
http://www.sciencelab.com/msds.php?m...8&code=SLM2677
http://www.sciencelab.com/msds.php?msdsId=9927358
I have actually worked with both and found that I was especially sensitive to the vapors from each (ie - above the norm). You may want to look at a clear urethane adhesive or something similar.
Of course, I have to ask... for what purpose are you adhering these two parts together? Is there an opportunity to use a mechanical fastening instead?
With 1370 --
Unread 15-02-2013, 23:45
Best Available Data
Originally Posted by Ian Curtis View Post
Hi everyone,
Thanks!
For the record I ended up using the SCIGRIP stuff because I never got a chance to run over and investigate something else between work, FIRST, and life. It actually worked pretty good when clamped in place and allowed to set, but I will definitely investigate other welding options in the off season as I'm not super happy with the way it looks.
Thanks for the suggestions!
  #15   Spotlight this post!
Unread 12-07-2013, 03:59
High Voltage High Voltage is offline
High Voltage is an unknown quantity at this point
The best adhesive you can use is a product called Channel Bond, it's specifically made for Polycarb to Polycarb bonding and it's a one part system so no need for a gun, tips, cardridges etc., you just pour back in the container when you're done. Using a Weld-on 3,4, 16 won't do it right. I bond huge polycarb faces for electric sign faces and this stuff works wonders. You can also use it to bond acrylic to polycarb. The only place I know you can get it is here, it does ship hazmat ground uness you can find a place that has it in stock so you can avoid the hazmat shipping fee
http://www.thesignsyndicate.com/foru...-now-shipping/
