| Thread Tools |
Rating:
Display Modes |
#16
Re: Bonding polycarbonate to polycarbonate
You could take a piece of 1/16" polycarb (we did this at one point last week), bow it around into a hopper and put two mounting screws through the overlap into your frame, making it sit in place but still look kinda cool...
#17
IPS Weld-On #16 works pretty well on polycarb. #'s 55 and 58 work even better. They're all 'solvent' cements, which likely means something like Methylene Chloride is the active ingredient. The nice part is that the heavier glue base is much easier to work with then a pure solvent.
I would not recommend using pure MEK or Methylene Chloride without a respirator and appropriate training. I use it at work but it's tricky stuff to use right and super toxic. Purpose made adhesives will give good results with far less risk and trouble. |
#18
MSDS #1 - http://www.curbellplastics.com/techn...c-weldon-4.pdf MSDS #2 - http://www.tapplastics.com/uploads/p...%204%20New.pdf |
#19
I use straight MC for repair work and #16 for making new parts or where I need a degree of gap filling. As long as you're very careful and have very clean edges, the wicking method makes for a better looking joint, for sure. |
#20
McMaster Carr has a bunch of adhesives that work great.
http://www.mcmaster.com/#adhesives/=lg4k4p Just wondering, how about Aluminum to a rubber/urethane? |
#21
I'd start with super glues. RTV should be good as well, and may work better. |
#22
Thanks for the suggestions! |
#23
The best adhesive you can use is a product called Channel Bond, it's specifically made for Polycarb to Polycarb bonding and it's a one part system so no need for a gun, tips, cardridges etc., you just pour back in the container when you're done. Using a Weld-on 3,4, 16 won't do it right. I bond huge polycarb faces for electric sign faces and this stuff works wonders. You can also use it to bond acrylic to polycarb. The only place I know you can get it is here, it does ship hazmat ground uness you can find a place that has it in stock so you can avoid the hazmat shipping fee
http://www.thesignsyndicate.com/foru...-now-shipping/ |
