Go to Post *Teams. The competitors, who wear brightly colored shirts, scream like crazy, and bring robots. Without them, there would be no competition. - EricH [more]
Unread 08-02-2013, 09:32
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
Team Role: Coach
Rookie Year: 2011
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Photosensor as encoder for bang bang.
Hello folks,
Helping my programmer do a bit of research. How would we go about pulling the period of time between rotations of a flywheel using a photosensor and tape to use with a bang bang in Labview.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 08-02-2013, 10:32
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Photosensor as encoder for bang bang.
Here's one way to do a tach with a photosensor:
Unread 08-02-2013, 18:08
Bunniy's Avatar
Bunniy Bunniy is offline
The Only Programmer
Rookie Year: 2012
Bunniy is an unknown quantity at this point
what is and where do i find the 'Dig Scr' thingy between the DIO open and the COUNTER open
Unread 08-02-2013, 18:28
Just Itinerant
It's in
WPI Robotics Library -> I/O -> DigitalInput
Unread 08-02-2013, 19:37
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Mark,
Is the Counter/ConfigTimer (blue arrow) where the FGPA sampling size is configured?
If so, does the "5" (green arrow) mean FPGA sample average is set to 5?
Does Counter/Get (red arrow) return the same thing as the GetPeriod() method in the Counter class in C++ and Java (i.e. period, in seconds, of the tooth count, based on the last 5 samples) ?
Thanks.
Unread 08-02-2013, 21:40
Just Itinerant
In a word, Yes.
The 5 there is just an example for # samples to average.
(For the OP's programmers, e.g., Bunniy) For example, if you have multiple pieces of reflective tape around the wheel to increase your resolution, then averaging removes any displacement errors in positioning the individual pieces of tape. You know, if the pieces of tape aren't perfectly spaced, perfectly sized, perfectly oriented. If you just use 1 piece of tape then I'd probably take the LabVIEW default of 1.
That Get wire is the average Period (in seconds) between pulses.
Unread 08-02-2013, 21:44
Ether's Avatar
Rookie Year: 1969
In a word, Yes.
For example, if you have multiple pieces of reflective tape around the wheel to increase your resolution, then averaging removes any displacement errors in positioning the individual pieces of tape. If you just use 1 piece of tape then I'd probably take the LabVIEW default of 1.
Thank you.
I have a more general LabVIEW question if I may. Before I posted the above question, I tried for about half an hour to find the answer on the internet. Do you (or does anyone reading) know of a site where you could type, say, "Counter Config Timer" into a search box and it would display the LabVIEW help screen for that icon? I had no success with Google.
Unread 08-02-2013, 21:53
Bunniy's Avatar
The Only Programmer
Rookie Year: 2012
Thank you mark for telling me that it should be set to 1. No wonder my wheel was spinning so fast!
Unread 08-02-2013, 22:04
Bunniy's Avatar
The Only Programmer
Rookie Year: 2012
im still having trouble. my motor keeps spinning as fast as possible even when i set the rpm to even 200.
Unread 08-02-2013, 22:15
Just Itinerant
Show a snippet of the code you're using.
I may be a little slow responding, I'm shoveling snow.
P.S.
If you don't know what a number in the example means, ask.
You don't want the 99 for example, because you only have 1 tick per revolution.
Unread 08-02-2013, 22:21
Ether, I don't know of a site that does that, but the editor will. If you click on search in the palettes, type Counter Config, it will have only one item in the list. Hover and the Context help window will show that item's help. There is also a function called QuickDrop that some folks just love. You hit Ctl-Space and type some of the name and it does the same sort of list and you click and drop the node. It doesn't look like the help updates until you drop the node.
Greg McKaskle
Unread 08-02-2013, 23:38
Bunniy's Avatar
The Only Programmer
Rookie Year: 2012
here
Unread 08-02-2013, 23:47
Bunniy's Avatar
The Only Programmer
Rookie Year: 2012
and this is the rest of it. The first picture us what is in the periodic task vi
Unread 08-02-2013, 23:53
Just Itinerant
So you're taking the total revs since the last time you checked the counter.
Dividing by a time constant, filtering the result, and applying a slew rate limiter?
I'm not a fan of the Counter reset applied that way. There's a window to drop counts.
Seems a bit much for flywheel.
Is the slew rate limiter to avoid extended stall time at full power for the flywheel?
P.S. I overlooked that the slew rate is probably bypassed with the False Case.
Is that really 360 counts per revolution?
I thought you only had 1?
I don't think you want that 60 or 360 applied there, but maybe I haven't grasped what you are calculating.
  #15   Spotlight this post!
Unread 09-02-2013, 00:03
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Are you trying to read buttons and set a global variable in Begin.vi? It only runs once when the program starts up, and usually isn't an appropriate place to do I/O actions.
