Go to Post Travel is a LOT less expensive when you pack the grown ups in the crate. - Rich Kressly [more]
Unread 02-08-2013, 12:06 PM
Arrowhead Arrowhead is offline
AKA: Daniel Brown
FRC #1369 (1369 Minotaur)
Rookie Year: 2013
Arrowhead is an unknown quantity at this point
Programming Vex Motor Controller 99
So our team is using a small vex motor, and as a result we are using a vex motor controller 99 to control it. Can we get any help with how to program this?
Unread 02-08-2013, 12:51 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Programming Vex Motor Controller 99
The input timing for the VEX 29 controller are very similar to the Victor. You should be able to use the Victor class.
Unread 02-08-2013, 12:52 PM
AKA: Daniel Brown
Rookie Year: 2013
Ok thanks, ill try it out in a sec
Unread 02-08-2013, 03:54 PM
AKA: Daniel Brown
Rookie Year: 2013
The victor class doesnt seem to be working
Unread 02-08-2013, 03:55 PM
At all? Have you installed the servo jumper on the PWM port you have connected the controller to?
Unread 02-08-2013, 03:57 PM
AKA: Daniel Brown
Rookie Year: 2013
We havent done, that, we are currently looking around our electronics bin for a jumper
Unread 02-08-2013, 04:02 PM
AKA: Daniel Brown
Rookie Year: 2013
We found a jumper on a old digital sidecar, and now everything is working
thanks
