Go to Post ASPCA would be happy to know you are petting your watchdog rather than kicking it. - Ether [more]
Unread 08-02-2013, 14:33
Wilt3dR0s3 Wilt3dR0s3 is offline
FRC #1361
Wilt3dR0s3 is an unknown quantity at this point
independent autonomous + Kinect integration?
Although somewhat early in the learning curve, autonomous is my focus for the bot, and I'm subjecting a way to move motors independently, through jaguar controls.
Is there a way to select which autonomous code runs based on a setting on classmate, controls, or other (i.e. 2 totally independent programs, with the ability to select which one right before starting?)
Secondly, I'm wondering if the kinect sensor is becoming a decently possible and useful addition (and, if late, it would be worth it to attempt to make it possible in the final run, sparing testing and a scrimmage or two).
This is my first post to CD, and I appreciate tips, tricks, and everything to push forward. I am a first year of a small team, and this also helps future projects, thank you. In advance, sorry for any confusing questions or problems.
