Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Unread 08-02-2013, 15:39
TDC94 TDC94 is offline
Junior Member
TDC94 is an unknown quantity at this point
Joystick: D-Pad to Assign L/R Joysticks to Different Motors
Is it possible to use the D-Pad of a gamepad to assign the joysticks to different motors.
For example. Pressing Up changes the joysticks to control an arm, Pressing Down changes the joysticks to drive mode.
Is this possible? Thanks.
Unread 08-02-2013, 15:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Joystick: D-Pad to Assign L/R Joysticks to Different Motors
Yes, it's possible.
Whether or not it's a good idea is another matter entirely. Why wouldn't you use a second controller (and a second person) to command the arm motion?
If you convince me that it's something you really want to do, I can give you some programming hints that will help you do it.
