Go to Post Hall of Fame FIRST Team 254 has arguably helped more teams become good than any other team in FIRST. I don't think they need a lecture on helping their opponents. - Karthik [more]
Unread 08-02-2013, 18:12
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
Rookie Year: 2010
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
Driver Station Loosing Communication
Hey ChiefDelphi,
We are trying to run code on to a 8 slot cRio. We have had no issues until today. What happens is we are able to deploy code to the cRio perfectly fine and like normal (we are using labview) and the robot will start up. We then can enable or disable the robot but we are hitting huge issues with communication. The robot code and communication lights on the driver station all of the sudden will go red and then come back on. This will happen around once every 2 seconds but it is super inconsistent. We have tried looking for shorts, unplugging the analog and digital modules in the cRio, etc. Sometimes we think something fixes it and then it will occur again. As for code, we don't see an issue as we time all of our vis and they all are running perfectly fine in terms of processing speed.
Here is the message in the dialog box on the driver station:
FRC: The Driver Station has lost communication with the robot.
Warning <Code> 44003 occurred at Driver Station
OR
FRC: No robot code is currently running.
Warning <Code> 44002 occurred at Ping Results: link-bad, DS radio(.4)-bad, robot radio(.1)-bad, cRIO(.2)-bad, FMS-bad Driver Station
Any suggestions? Thanks.
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
Unread 08-02-2013, 18:29
bgg's Avatar
bgg bgg is offline
FRC #3679
bgg is an unknown quantity at this point
Re: Driver Station Loosing Communication
We've run into similar situations before. In both cases it was a wiring problem. With the robot stationary it worked fine but the slightest vibration caused communication failure. Three likely sources to check for secure wiring: power to crio (both on crio and where crio connects to pd board) and router connection on pd board.
Unread 08-02-2013, 19:23
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
That error suggests the ping to both the radio and cRIO failed. Is this happening over wireless, wired or both. If wired are you going through the radio or direct to the cRIO?
Unread 08-02-2013, 20:56
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Does it happen only when using wireless networking? There might be a nearby wireless access point interfering with your communication. If you have a way to scan for wireless networks, maybe you can find a relatively clear 802.11 channel and configure your D-Link to use that channel instead of letting it pick one on its own.
Unread 14-02-2013, 19:40
mccode2512's Avatar
mccode2512 mccode2512 is offline
AKA: Christine
FRC #2512 (Duluth East Daredevils)
Rookie Year: 2011
mccode2512 is an unknown quantity at this point
We are having the exact same problem as stingray27. I'm fairly sure it's not a wiring issue because this only happens when connecting wirelessly and it happens even if the robot is not moving. There is a high probability of other networks interfering with the communication; Alan, how could one tell if an 802.11 channel is relatively clear? We've had communication problems both at our school and our racing company mentor's garage.
Unread 14-02-2013, 22:34
OWilliamson's Avatar
OWilliamson OWilliamson is offline
FRC #2594 (NASKCO)
Rookie Year: 2012
OWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of light
How is your bridge attached to tour robot because we had a similar issue and we think that it is because of our mount was made out of metal so we are now replacing our mount with on made out of plastic.
Unread 15-02-2013, 17:54
mccode2512's Avatar
AKA: Christine
Rookie Year: 2011
Our bridge is attached to plastic using zip-ties and velcro.
Unread 16-02-2013, 17:14
dieDoktor dieDoktor is offline
AKA: Kipling Cohen
FRC #4118 (Roaring Riptides)
Team Role: Mechanical
Rookie Year: 2011
dieDoktor is an unknown quantity at this point
Did this work for you? As we are having a similar issue.
Unread 16-02-2013, 17:22
JM033's Avatar
JM033 JM033 is offline
AKA: J
FRC #0240 (Tempest)
Team Role: Leadership
JM033 is an unknown quantity at this point
Yes, we too have the error exactly. Even if it is hardwired to the radio. It doesn't seem to affect anything in any way though; our code runs fine. We are using 6-slot crio with the new dLink.
Unread 16-02-2013, 00:25
Software Architect
...how could one tell if an 802.11 channel is relatively clear?
Use a WiFi scanner program such as NetStumbler or inSSIDer to see what wireless access points are nearby and what channels they're using.
