Go to Post Just think of the deadline as your six week deadline for FIRST, just when you think you can't do it, you are amazed by what you can do. - JackN [more]
Unread 08-02-2013, 19:22
Team 4457 Team 4457 is offline
FRC #4457
Team 4457 is an unknown quantity at this point
PWM Channels Not Responding?
Hey, so here is our problem:
We are using two talons to run a four motor drive train (we are sure that that is not the problem) and we are correctly wired and all the wires work. But when we go to run the robot, only one of the two PWM channels work (this was determined by swapping around cables). The joysticks both work. Does this mean that this is a programing issue? If so, do you have any idea what is could be?
Thank you,
Team 4457
~There are always choices, some are just harder to make than others.~
Unread 08-02-2013, 20:40
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: PWM Channels Not Responding?
Actually, I'm willing to bet that this is A problem. It might not be the one you're trying to solve, but there are very specific motors that can be run with more than one motor per speed controller, and most of the common drive motors do NOT fall into that category, especially CIMs. Take a good look at R52 and your drive motors' part numbers. (If you're using motors that are legal to run two to a speed controller... well, that's your decision, but those motors tend to be weaker than, say 4 CIMs through the KOP gearbox when used in drive.) Your regional's inspectors will almost certainly catch that one.
(See prior statement on legality of wiring two motors to one speed controller... but I digress.) You could just have a bad PWM cable. There could be other factors in play, however, so here are a couple of diagnostic questions for you.
What are the lights on the Digital Sidecar doing?
What is the light on the Talon doing on the channel that does not work?
What channels are you plugged into, and what channels is your code controlling with the joysticks? (Have you tried other channels to see if they work?)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
