Deadzone Programming
I looked around a bit but couldn't find any resources on this for c++
How do you program in a deadzone for a attack 3 joystick? I wrote this code but it doesn't seem to be working. Code:
void driving(){
double y; //variable for forward/backward movement
double x; //variable for side to side movement
double turn; //variable for turning movement
if(driverStick.GetY()>0.3||driverStick.GetY()<-0.3){
y=driverStick.GetY();
if(driverStick.GetX()>0.3||driverStick.GetX()<-0.3){
x=driverStick.GetX();
if(driverStick2.GetX()>0.3||driverStick2.GetX()<-0.3){
turn=driverStick2.GetX();
Re: Deadzone Programming
Try this, you need to set default values. Also I just cleaned it up a bit.
Code:
void driving(){
double y = 0; //variable for forward/backward movement
double x = 0; //variable for side to side movement
double turn = 0; //variable for turning movement
double deadzone = 0.3; //variable for amount of deadzone
if(driverStick.GetY() > deadzone || driverStick.GetY() < -deadzone) {
y = driverStick.GetY();
if(driverStick.GetX() > deadzone || driverStick.GetX() < -deadzone) {
x = driverStick.GetX();
if(driverStick2.GetX() > deadzone || driverStick2.GetX() < -deadzone){
turn = driverStick2.GetX();
Ok, thanks, I'll try that at practice on monday.
Also, how does setting default values for those variables change it? |
Well, if you don't and you try to use it later after the if statement failing the value is set to null and you'll get an error.
We've found the following to work great for dead zones. The main advantage is you can still generate values between 0 and .3. With the previously posted solution once you get out of the dead zone you're instantly outputting .3 or 30%. If you notice we have a lot of 127s in the middle of the array. Those provide the dead zone but we shift everything else over so that once your out of the dead zone it doesn't go straight to .3.
This was written on the old control system. Technically the cRio has enough power to run the equation we are using to generate the array. We've just never taken the time to switch it over. Code:
const char inputShape[255] = {0,1,3,4,5,6,7,9,10,11,12,13,15,16,17,18,19,21,22,23,24,25,27,28,29,30,31,
33,34,35,36,37,38,40,41,42,43,44,46,47,48,49,50,52,53,54,55,56,58,59,60,61,62,
64,65,66,67,68,70,71,72,73,74,76,77,78,79,80,82,83,84,85,86,88,89,90,91,92,94,
95,96,97,98,100,101,102,103,104,106,107,108,109,110,112,113,114,115,116,117,
118,119,120,121,121,122,123,123,124,124,125,125,125,126,126,126,126,126,127,
127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,
128,128,128,128,128,129,129,129,130,130,131,131,132,133,133,134,135,136,
137,138,139,140,141,142,144,145,146,147,148,150,151,152,153,154,156,157,158,
159,160,162,163,164,165,166,168,169,170,171,172,174,175,176,177,178,180,181,
182,183,184,186,187,188,189,190,192,193,194,195,196,198,199,200,201,202,204,
205,206,207,208,210,211,212,213,214,216,217,218,219,220,221,223,224,225,226,
227,229,230,231,232,233,235,236,237,238,239,241,242,243,244,245,247,248,249,
250,251,253,254,255};
float InputShape(float userValue)
int iUserValue;
iUserValue = (int)(userValue * 127);
iUserValue += 127;
iUserValue = inputShape[iUserValue];
userValue = iUserValue - 127;
userValue /= 127;
return userValue;
--SNIP--
ly = InputShape(stick->GetRawAxis(2));
ry = InputShape(stick->GetRawAxis(5));
It comes from whatever line calls the InputShape() function.
Gah, wasnt paying attention lol
Code:
#include <math.h>
void driving() {
double y = driverStick.GetY();
double x = driverStick.GetX();
double turn = driverStick2.GetX();
if(fabs(y) < deadzone)
y = 0;
if(fabs(x) < deadzone)
x = 0;
if(fabs(turn) < deadzone)
turn = 0;
Code:
#include <math.h>
void driving() {
y = ((fabs(y) < deadzone) ? (0) : (y));
x = ((fabs(x) < deadzone) ? (0) : (x));
turn = ((fabs(turn) < deadzone) ? (0) : (turn));
#10
Thanks! Also, did you mean abs() instead of fabs()?
#11
abs() takes an int and returns an int. fabs() takes a float and returns a float.
Since Joystick::GetX() and GetY() return floats, he did mean fabs(). |
#12
Ah, thanks for the correction.
