pic: Team Drift 4091 Crate Stand
Re: pic: Team Drift 4091 Crate Stand
Looks like a cool idea, but how will you make sure this stays under the 400lbs limit (if using the FedEx FIRST agreement). and where would this be going in your pits? it seems like it would be a little big for you to have an space in your pits
It is already build, and is all aluminum under 200 pounds + robot under 80 pounds because we are using carbon fiber this year is way under 400 pounds. And sizes is according to pit size.
Your robot is under 80 lbs this year? I'm not saying that's impossible, but as we weighed it out, the controls alone are about ~50lbs so that's one small robot.
Yes is small and our shooter was build using small wheels and bag motors, we are not picking Frisbees from floor and our 30 point climbing mechanism is using winches.
It's totally possible. We will have to add ballast to make it to 80lbs.
also we made our own transmisions using aluminum gears
What do you intend to use all the dead space behind it for?
tools
#10
Remember the weight of the bumpers. assuming you will be storing them in there.
#11
that does not count in the robot weight.
#12
But it would count toward crate weight--40 lb total if you had 2 sets at max weight.
#13
Thanks for the comments, we are aware about weight of the crate the robot. Just wanted to share what we have done.
