Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 02-09-2013, 10:39 AM
Mr.Roboto3335's Avatar
Mr.Roboto3335 Mr.Roboto3335 is offline
Wait, What?
AKA: Jimmy
FRC #3335 (Cy-Borgs)
Rookie Year: 2011
Mr.Roboto3335 is an unknown quantity at this point
Servo programming
I'm having trouble trying to program a servo. Everytime I press the button that should make it rotate it does nothing. Any help would be appreciated.
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Servo;
import edu.wpi.first.wpilibj.SimpleRobot;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the SimpleRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class RobotTemplate extends SimpleRobot {
Servo servo = new Servo(5);
Joystick joystick = new Joystick(1);
* This function is called once each time the robot enters autonomous mode.
public void autonomous() {
* This function is called once each time the robot enters operator control.
public void operatorControl() {
if(joystick.getRawButton(3))
servo.set(1);
else if(joystick.getRawButton(4))
servo.set(-1);
* This function is called once each time the robot enters test mode.
public void test() {
Wait, what?
Last edited by Mr.Roboto3335 : 02-09-2013 at 10:40 AM. Reason: The code was a mess
Unread 02-09-2013, 11:28 AM
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Servo programming
Code:
servo.set(1);
servo.set(-1);
This should be running in a loop. Like this
Code:
while(isOperatorControl()) {
    // Code here
All opinions are my own.
Unread 02-09-2013, 11:33 AM
Wait, What?
AKA: Jimmy
Rookie Year: 2011
You are absolutely correct. I forgot that statement. Servo still won't work. It doesn't even default when I reset the robot. Wiring?
Wait, what?
Unread 02-09-2013, 11:43 AM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Also, Servo.set() takes a value from 0 to 1, rather then -1 to 1 like a motor.
You can also use code tags to keep your formatting when posting code.
Did you install the servo jumper in the digital sidecar?
Unread 02-09-2013, 11:48 AM
Wait, What?
AKA: Jimmy
Rookie Year: 2011
No I did not... Found and inserted the jumper and is now working. Thank you!
Wait, what?
Unread 02-17-2013, 07:24 PM
tmccalister tmccalister is offline
FRC #2985
tmccalister is an unknown quantity at this point
What is a servo jumper? If you could help me with that just pm me. Thanks
Unread 02-17-2013, 07:28 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Jump to 0:24 in this video:
http://www.youtube.com/watch?v=RF104...me0nC_xUILWCam
Unread 02-18-2013, 06:36 PM
FRC #2985
Originally Posted by Ether View Post
What does it look like?
Unread 02-18-2013, 09:02 PM
Ether's Avatar
Rookie Year: 1969
It looks like the picture in the 2013 Kit of Parts black tote checklist revB.
