Go to Post FIRST robots are not six week projects. They are never ending projects where the requirements are changed on an annual basis. - ChrisH [more]
Unread 09-02-2013, 11:37
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
Rookie Year: 2013
akash992391 is on a distinguished road
how to program shooter on LabVIEW
hiii
can someone help me with our shooter programming.our robot consist 2 CIM motor connected to the pneumatic tires and we are using jaguar.i tried programming it but it didnt work.
Unread 09-02-2013, 11:40
Re: how to program shooter on LabVIEW
Please give more details about what you have tried, possibly even putting up the code or a picture of the code. That will allow others to help you improve rather than telling you how they would do it.
Greg McKaskle
Unread 09-02-2013, 11:49
AKA: Akash
FRC #4684
Rookie Year: 2013
here it is
Unread 09-02-2013, 12:49
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
That will only initialize your drivetrain, not your shooter. To initialize your shooter, do something like you see in the attached picture.
Then, to make the motor run, you need to configure something in your Teleop.vi. How you come up with a value is up to you, but it should be from -1 to 1 and should be fed into a Set Output vi. (I've attached a screenshot.)
ID:	13876  Click image for larger version
Unread 10-02-2013, 12:57
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you really do want both of the shooter motors to run as a single unit, you can use a "2 motor Drive" for them. But when you save the RefNum, you should give it a name that describes what it is. The "Left and Right Motors" RefNum name is already being used to set the actual drive motors. Make it "Shooter Motors" instead.
But I would open them as two separate motors instead of a "Drive" pair. If I wanted them to always run at the same speed, I would actually open them as a single motor and use a PWM Y cable to send one control signal to two speed controllers at the same time.
