Go to Post There is nothing cooler than engineers playing rock music. - Jay Trzaskos [more]
Unread 02-09-2013, 01:44 PM
gman gman is offline
FRC #4024
gman is an unknown quantity at this point
Code running slow
We've set up our robot's code using java to run Jaguar motor controllers via a DriveTrain subsystem. Thing is, the DriveTrain's execute() method is only being called once every 10-15 seconds. This means that we push the joystick forward, wait a few seconds, and the wheel starts spinning, then, when we release the joystick, we have to wait another 10-15 seconds for it to update again to stop. If you need code/other information, let me know and I'll post it. Thanks in advance.
Unread 02-09-2013, 01:57 PM
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Rookie Year: 2012
Team3266Spencer is an unknown quantity at this point
Re: Code running slow
What format of code are you using? The command-based?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 02-09-2013, 02:00 PM
FRC #4024
Yes, command-based.
Unread 02-09-2013, 02:10 PM
AKA: Spencer Lanman
Rookie Year: 2012
Have you checked to see if its a networking issue, are you losing packets?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 02-09-2013, 02:15 PM
FRC #4024
We put some print statements next to the command statements; they're running just as slowly on the computer, so I don't think it's a network thing. Also, he computer is wired directly to the dlink at the moment (wireless cut out for some reason). If you have other suggestions on how else to test the network, let me know and I'll try it.
Unread 02-09-2013, 02:19 PM
AKA: Spencer Lanman
Rookie Year: 2012
You don't have two driverstations open do you?
This happens sometimes when there's one open on the driver account and one open on the developer account.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 02-09-2013, 02:57 PM
FRC #4024
No, I even restarted the computer just to make sure. Only one driver station running. We're going to try reimaging the cRIO without the CAN drivers to see if that is having some effect.
Unread 02-09-2013, 03:15 PM
FRC #4024
We tried running it without the CAN plugin, no luck, we're reimaging the entire thing.
Unread 02-09-2013, 04:02 PM
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
The commands are run by repeated calls to Scheduler.run(). Make sure that it's being called in the teleopPeriodic() or autonomousPeriodic() methods in the main robot project like this:
Code:
    public void teleopInit() {
	// This makes sure that the autonomous stops running when
        // teleop starts running. If you want the autonomous to
        // continue until interrupted by another command, remove
        // this line or comment it out.
        if (autonomousCommand != null) autonomousCommand.cancel();
     * This function is called periodically during operator control
        Scheduler.getInstance().run();
Also you can verify that the commands are running by writing the Scheduler instance to the SmartDashboard as shown in this web page:
http://wpilib.screenstepslive.com/s/...and-subsystems
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 02-09-2013, 04:25 PM
FRC #4024
We have the Scheduler.getInstance().run() in the code already. I tried the SmartDashboard thing, its says it's running. I have print statements in the execute() method, they running, but only once every 10-15 seconds.
Unread 02-09-2013, 04:55 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Try deploying a blank SimpleRobot project with a print statement in the operator control method
Unread 02-09-2013, 05:33 PM
AKA: Brad
Can you put a print statement in the teleopPeriodic() method to see how often it (and Scheduler.run()) is getting called. It should be about every 20ms (50 times per second).
Brad
Brad Miller
Unread 02-10-2013, 04:27 PM
FRC #4024
We tried running a simple robot; the problem does not occur. We tried putting the print in the teleopPeriodic; it was being called about once every 10 seconds.
Unread 02-10-2013, 04:39 PM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
I think the issue is you are using loops in your code.
Iterative and Command based robots should NOT be using "while" or "for" loops (generally) in their code. The methods are already looped for you, and long loops will mean that any "simultaneous" commands will be put on hold until the loop is complete.
The Simple template handles looping code by interrupting it periodically, and so you won't see any issues there.
In life, what you give, you keep. What you fail to give, you lose forever...
  #15   Spotlight this post!
Unread 02-10-2013, 04:55 PM
FRC #4024
We double checked, there are absolutely no for or while loops anywhere in the program...
