Go to Post I love it when there is someone that obviously "gets it". - dlavery [more]
Unread 09-02-2013, 17:17
zackd97 zackd97 is offline
FRC #4102
Rookie Year: 2013
zackd97 is an unknown quantity at this point
RobotBuilder Help
This is my first year working on FIRST and I've been given the task of programming our robot. I have no experience with c++, but I have done work with C. So far I've managed to create a whole project on RobotBuilder and get motors running with joystick buttons and all that, but I have no clue on what to do for the actual driving of the robot. It would be nice if I could do something similar to the simple robot arcade drive stuff or incorporate that actual code into my own, but I don't know what to do to do that. Any help at all would be greatly appreciated. If you would like to see my program or anything feel free to ask. Thanks!
Unread 09-02-2013, 17:28
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: RobotBuilder Help
See if this article helps: http://wpilib.screenstepslive.com/s/...-and-joysticks
If you want to use arcade instead of tank just replace the joystick axes used as appropriate and replace the TankDrive method with the ArcadeDrive method.
Unread 09-02-2013, 17:38
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
There is also a video here:
http://www.youtube.com/user/BradAMil...ow=grid&view=1
(look at the RobotBuilder playlist) that shows how to build a complete program using RobotBuilder. The example is with Java, but the C++ code is almost the same. I think you'd get the idea.
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
