Go to Post When a vomit shooter runs out of balls, is it dry heaving? :p - Lil' Lavery [more]
Unread 09-02-2013, 20:59
matthewkennedy matthewkennedy is offline
FRC #1294 (Top Gun)
Rookie Year: 2011
matthewkennedy is an unknown quantity at this point
Module already loaded on target
This seems like there's something easy that I'm missing.
So, the problem: I'm having a problem debugging to the cRIO from WindRiver. If I debug a project on the cRIO, fix something, recompile, and then hit debug again, I get this dialog box. What is the proper way to debug something, then debug again without rebooting the cRIO?
-Matthew
"The future is already here—it's just not very evenly distributed"
-William Gibson
Unread 09-02-2013, 21:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Module already loaded on target
Are you undeploying code and rebooting first so you don't have anything already running on bootup on the cRIO?
Unread 09-02-2013, 21:27
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
The current WPILib will error out even if you solved the current problem. If the ~25 seconds for the cRIO to reboot (you can even do it remotely from WindRiver or the DS software) is a factor in your debugging process, I would seriously suggest you need to slow down and make your changes more methodically.
Unread 10-02-2013, 16:41
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
Rookie Year: 2011
nightpool is on a distinguished road
Or use python, which allows for a better and more responsive design cycle
Proud alum of CORE 2062.
www.core2062.com
Unread 10-02-2013, 20:52
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Previously I have been able to stop the RobotTask, unload my debug-deployed '.out' file, and then could reload it from the debugger and start it again. This year, I have not been able to; I get strange exceptions. It seems that the only reliable way to deploy a new version for debugging is to Reset the cRio.
