Go to Post If my counts are correct, during the official matches 141,077 points were scored, and a minimum of 28,746 frisbees were successfully shot into goals. All without a single decapitation, severed limb, or even one porpoise becoming accidentally entangled in the nets. - dlavery [more]
Unread 10-02-2013, 10:34
akosin's Avatar
akosin akosin is offline
AKA: Austin
FRC #4288 (Worcester Beach Bots)
akosin is on a distinguished road
Compressor Wiring
We were wiring our compressor to the robot today with the compressor leads to a spike and the pressure switch to the digital sidecar. When one of our mentors asked why I wasn't just wiring the compressor directly to the power board with the switch in series. We tried it and it worked great. Is this legal, or do I have to go back to the old wiring method?
Thanks,
Austin
"When you’re screwing up and nobody’s saying anything to you anymore, that means they gave up."
-Randy Pausch
"The Last Lecture"
Unread 10-02-2013, 10:38
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
Re: Compressor Wiring
No, you must run the compressor through a Spike and use the Nason switch to tell your code to turn the compressor off.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 10-02-2013, 11:06
petet4 petet4 is offline
AKA: Pete Thomas
FRC #0706 (Cyberhawks)
petet4 is on a distinguished road
First of all it is illegal to wire the switch like that and second the switch is not rated for the current the compressor will draw, it my work for awhile but will soon fail.
Here is the data for the switch
-pete
Unread 10-02-2013, 12:20
akosin's Avatar
AKA: Austin
Ok
Thank You for your help!
-Randy Pausch
"The Last Lecture"
Unread 10-02-2013, 12:27
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Over the years I have learned many things from the FIRST team students I have mentored. The suggestion your mentor made about wiring the pressure switch directly to the compressor indicates a great opportunity for that mentor to learn from you now. The mentor's suggestion was well-intended, I believe, but was not based on a complete understanding of the rules and risks, as Pete explained above.
For reference, the pertinent rules are <R52> and <R87>. You should read them carefully before you explain to your mentor how the compressor and pressure switch wiring must be done.
I have inspected FRC robots at many events for several years. Many times I have seen the incorrect switch wiring that your mentor suggested, and have made the team correct it before their robot passed inspection. Once (thankfully only once!) I saw this kind of incorrect wiring result in a serious safety issue -- the switch, which as Pete pointed out is NOT rated for the electrical loading presented by a compressor, had failed due to arcing at its contacts, which fused them closed so that the compressor ran continuously -- until it overheated and smoke started to pour out. Luckily a heads-up field volunteer reached the robot's main breaker and stopped it before things got much worse.
Richard Wallace
since 2003
Unread 19-02-2013, 18:35
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
... and I've seen mentors sticking compressor wires into the red Anderson battery connector(!!!). In a great demonstration of GP, FRC3256 (Valley Christian HS) loaned/scrounged the parts and helped the other team build a compliant pneumatic system in the pits at SVR.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
