Go to Post Quitting FIRST was so hard that I felt like I needed a 12 steps program to help me through it. - Ken Leung [more]
Unread 10-02-2013, 15:31
roboticsx roboticsx is offline
FRC #4751
roboticsx is an unknown quantity at this point
How can you make turning smoother?
does anyone know how to make turning smoother? our robot movement is too jerky...
Unread 10-02-2013, 15:32
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
Rookie Year: 2007
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
Re: How can you make turning smoother?
What kind of drive train are you running?
Unread 10-02-2013, 15:33
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Run a 6 or 8 wheel tank drive with the center wheel(s) dropped 1/8".
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Unread 10-02-2013, 15:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Run mechanum wheels?
Any kind of tank drive with grippy wheels or tracks are going to have issues turning smoothly. It is because you have to slide the wheels side way. There are compensations: short wheel base, six wheel drive with a dropped center wheel, etc. Having enough torque is also critical. Either by two cims per side or low enough gearing.
Unread 10-02-2013, 15:54
Happy Birthday! Akash Rastogi Akash Rastogi is offline
Please post a picture of your drivetrain so we can help you better.
Unread 10-02-2013, 19:15
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Chris Hibner's white paper should be required reading for anyone worried about smooth turning.
Unread 11-02-2013, 13:59
stveception stveception is offline
FRC #1660
stveception has a spectacular aura aboutstveception has a spectacular aura about
Square the inputs from your joystick into your robot drive. This will make the joystick less sensitive.
Unread 11-02-2013, 15:00
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Hey... one of the new Calgary teams! Welcome aboard, and welcome to Chief Delphi. I'm hoping to get out to Calgary this year, and look forward to seeing your machine.
We had this problem with our first robot, a four wheel drive machine... it worked great on our cement and linoleum floors at school, but when we finally got to Toronto and put it on carpet... we couldn't turn worth a darn.
The problem is inherent to skid steering... the front and rear of the robot needs to skid sideways, in order for the robot to turn. Since we design the robots to have high traction wheels (which were great for pushing) they were awful for turning. We had to reduce the coefficient of friction of one set of wheels so that they could slide sideways.
With a six or eight wheel drive (which we eventually switched to) the trick is to lower the centre wheels... this reduces the "normal force" (hey, physics in action) on the front and rear wheels, making it easier for them to skid sideways.
If you are locked into a four wheel drive design, you might want to consider some omni wheels... http://www.andymark.com/Omni-s/51.htm they also work great with six and eight wheel drive machines.
Good luck! Hope you get the machine running well soon.
Jason
Unread 11-02-2013, 20:55
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Rookie Year: 2011
Jibri Wright will become famous soon enough
Jason
It doesnt cause the normal force to decrease. What happens is that the centripetal force when pivoting on the dropped wheels causes the outer wheels to lift and cause them to be in a state of balance with each other. While pivoting the outer wheels are applying no force to the ground or in other words not touching.
Unread 11-02-2013, 21:17
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Um... yes it does.
Where are you getting your information?
Unread 12-02-2013, 12:00
Team Role: CAD
Rookie Year: 2011
Originally Posted by Ether View Post
Um... yes it does.
It doesn't cause normal force to technically decrease. When driving forward or backwards, there are at least four wheels on the ground. During this time, the amount of normal force on the dropped wheels as well as the normal force on the set of outer wheels is evenly distributed and the same. When the robot is pivoting on the dropped wheels, the normal force pushes in tangential to the place of pivot, this case being the dropped wheels. Inertia therefore causes the outer wheels to lift and balance which in turn means the dropped wheels are the only wheels touching the floor at this moment. I got this information from A.P. Physics B where I am currently getting a high B in. I learned of centripetal force last year and asked my mentor who also happens to be my A.P. Physics teacher is this what caused a dropped 6wd to turn smoothly. He said yes.
Study centripetal force and you'll know what im talking about.
Unread 12-02-2013, 12:13
Ether's Avatar
Rookie Year: 1969
You need to go back and read Jason's post more carefully:
Dropping the center wheels has exactly the effect described above by Jason, and this is the main reason why dropping the center wheels slightly makes the robot easier to turn.
Could you please politely ask him to send me a PM?
Unread 12-02-2013, 13:10
Team Role: CAD
Rookie Year: 2011
Sure but he isn't on this website. Can you PM me your email? That way he can get in touch with you. He's the one that founded our robotics team and not really an engineer, but helps us determine how things should theoretically behave.
Unread 12-02-2013, 14:45
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Jibri, what Ether is saying is that when you have weight centered on the robot and you add two dropped wheels, the weight is more distributed over the center wheels than the outer wheels, causing a higher normal force on the center wheels than either the front or back set of wheels. Your point about the centripetal force is still valid though.
  #15   Spotlight this post!
Unread 12-02-2013, 14:50
Team Role: CAD
Rookie Year: 2011
I just talked to him. He said that the centripetal force does cause the outer two wheels to lift. Its the same force that NASA is currently studying to create "artificial gravity" in space stations. Centripetal force (in the form of static frictional force in this case) pulls inward and the outer wheels are pulled out parallel two the floor. As the robot begins to pivot, the centripetal force is out of balance. If you have ever done work using vectors, you can tell that one of the outer wheels on the ground and one wheel floating is what causes this imbalance. The centripetal force in turn forces a balance by making the forces on the two outer wheels equal a.k.a. set their vectors parallel to each other.
Think of it like a spinning top. When the top isn't spun, it is laying sideways on the table right? But when you spin it, it balances on a single point that touches the table, almost as if defying gravity. The force that is causing the top to balance is the same force that is causing the outer two wheels to lift.
My mentor also said that this observation is not as observable with an FRC 6wd because the dropped wheel is not dropped enough to notice, the FRC field carpet is too high to notice, FRC robot weight normally isn't evenly distributed on both sides of the robot, etc. so its hard to notice and may not come fully off the ground, but the wheels do lift.
He also said that this only occurs when the robot is pivoting. When the robot is driving forwards or backwards, four wheels are normally touching the ground and the weight (or as you said normal force) is even on all four. One set of wheels will be off of the ground and none of the weight will be on those wheels.
To put it plainly, since the wheels are probably touching the carpet when pivoting, normal force is decreased on the outer wheels when pivoting but not because of the dropped wheel. It is because of the centripetal force acting on the robot by tangential friction. Because a lot of Newtonian mechanics use a lot of the same measurements like Newtons, seconds, meters, etc.., it isn't always easy to figure out exactly what causes what. Even so in this case, it is centripetal force. The dead giveaway is the circular motion.
Btw Ether, love the Einstein picture. I love how he's the father of quantum mechanics yet dedicated his life to proving it wrong!
