pic: Marauder Drive
Re: pic: Marauder Drive
The Render Took me about 4 Hours 30 Min on a
AMD FX-8150 @ 3.9Ghz (8 Core) Water Cooled 8Gb of Kingston HyperXT1 memory @ 1600mhz Western Digital Velociraptor SATAIII GTX480 Resolution : 15360x8640 which is 16k or digital cinema quality Hope you enjoy ![]() |
I can not wait to see how this works!
- Andrew |
Looks really heavy. What sort of weight is it?
Ya unfortunately there pretty heavy, about 15lb a piece
I love it heavy or not, a cheesed version would be really cool
Ours were 20 a piece at one point...
I designed a similar gearbox with a high/low and a drive/climb shifter! I just need to come up with a brake like you have. How do you stop the gear? I see the pneumatic piston, but what is on the end of it?
I'll be posting pics/vids of it soon, but all it is is a small piece of rack on a sliding block, the key is to software assist it so your not jamming it into the gear ruining the teeth. Also the piston needs minimal pressure (<5psi) so its possible to use the spring loaded pistons, or possible even a servo ( gonna try that one out sometime soon ).
