Go to Post oooo can i get bear hugged at monty madness...please big mike, please - Rohith Surampudi [more]
Unread 11-02-2013, 15:24
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Rookie Year: 2011
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Question Jaguars mounted upside down?
Is there a risk of mounting our jaguars upside down, suspended above the ground and our drivetrain motors? My main concerns are tat they are too susceptible to damage there and that they will overheat. So, is it safe to mount them there, should we find another place to put them?
EDIT:: The concensus seems to be that we shouldn't have any problems. I was just a bit panicky because our previous experience with Jaguars were filled with smoke and melted plastic...
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 11-02-2013, 15:26
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Jaguars mounted upside down?
In 2009, we hung about 8 of the Tan Jaguars upside-down with no problems whatsoever (other than the design people left no room to access them for troubleshooting). Just make sure if you use PWM, use the strain relief tab so the connectors don't easily fall out. Hot glue works well, too.
I'm right 90% of the time, so why worry about the other 3%?
Unread 11-02-2013, 16:11
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
The orientation of the Jaguar should not affect thermal performance. Impeding the airflow around them will.
Unread 11-02-2013, 16:44
Tmaxxrox97's Avatar
Tmaxxrox97 Tmaxxrox97 is offline
FRC #2512 (Duluth East Daredevils)
Team Role: Mechanical
Rookie Year: 2011
Tmaxxrox97 is an unknown quantity at this point
My team has mounted them upside down for a few years now. We actually prefer having them upside down as metal shavings can't get into them and they are protected more because they can't get hit by a game piece, field element, other robot, etc. just make sure to keep them up off the ground a little bit to prevent rubbing. Also they probably won't overheat as they have fans to help keep them cool.
Good luck.
