Go to Post The goal isn't to keep the "bad" kids out. The goal is to take the "bad" out of kids, thereby transforming OUR culture. - Michael Corsetto [more]
Unread 11-02-2013, 15:33
realslimschadey realslimschadey is offline
FRC #0870 (R.I.C.E.)
realslimschadey is an unknown quantity at this point
Programming Shooter C++
I'm programming in c++ and i cant get the shooter to work. All i want it to do is when i press a button on the joystick, it runs the motor and if im not touching the button the motor doesnt run. How do i do this?
Unread 11-02-2013, 16:04
mrklempae mrklempae is offline
mrklempae is an unknown quantity at this point
Re: Programming Shooter C++
I have no idea what your setup is, but it would look something like this:
Code:
while (IsOperatorControl())
			bool Button =joystick -> GetRawButton (3);
			if (Button)
				Motor1->Set(1);
                        else if (!Button)
                               Motor1->Set(0);
Unread 11-02-2013, 16:53
The button is 2, and the motor is Shooter. Im still having problems
Unread 11-02-2013, 17:35
Arrowhead Arrowhead is offline
AKA: Daniel Brown
FRC #1369 (1369 Minotaur)
Rookie Year: 2013
Arrowhead is an unknown quantity at this point
Can you post your current code?
Unread 11-02-2013, 18:13
JCrusoe JCrusoe is offline
Jacque Crusoe
FRC #3880 (Tiki Techs)
Rookie Year: 2010
JCrusoe is an unknown quantity at this point
Smile Re: Programming Shooter C++
Without your current code its hard to tell what the issue is, but I would make sure that you have it in the constructor correctly. I'm going guess that its a Jaguar, but it could easily be a Victor as well.
Code:
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	Jaguar shooter;
	Joystick driveStick; //it can be any name, not strictly driveStick :)
public:
	RobotDemo(void):
		//JAGUARS//
		shooter(1),	    //This is what port your shooter motor is in on the Sidecar
		//JOYSTICKS//	// These must be initialized in the same order
		driveStick(1)	// as they are declared above.
		shooter.SetExpiration(0.1);  //for Driver Station
	void Autonomous(void)
			//where your autonomous would go
	void OperatorControl(void)	//The Operator Control, what you're looking for!
			if(driveStick.GetRawButton(2)) //This is a structure that says if 2 is pressed, shooter
			{							   //will be set to 100%
				shooter.Set(1.0);
			else                           //anytime when it isn't pressed (else), the shooter will turn
			{							   // off
				shooter.Set(0.0);
			Wait(0.005);  // wait for a motor update time
	void Test()
		//what runs during test mode
START_ROBOT_CLASS(RobotDemo);
