Go to Post Better is the enemy of good enough. - petek [more]
Unread 11-02-2013, 16:41
Cfleming_3929 Cfleming_3929 is offline
FRC #3929
Cfleming_3929 is an unknown quantity at this point
Arduino Leonardo Recognized as Joystick
Hey, I'm on the second year team, the Atomic Dragons (3929). I'm on the programming team and don't have much experience. I was wondering if anyone else was working on an Arduino Leonardo board? If so, how do you get the FRC driver station to recognize it as a joystick?
Unread 11-02-2013, 17:17
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
Rookie Year: 2010
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Re: Arduino Leonardo Recognized as Joystick
I am planning on having us try the Leonardo out this year instead of the Cypress board. It arrived this morning, so I haven't tried it yet. There are some decent resources on the web available, and I'll dig up what I found later tonight. Once we get it going I'll post some info here.
In short, you need a descriptor for your 'joystick' so you can describe the buttons etc that you are going to have, and then from your Arduino code, write your values to the computer as a report of the joystick state. Again, some resources where people have done this is helpful, and I will post some later.
Keep in mind having it show up as a joystick is not the same as how the Cypress board showed up in the Driver Station software, as far as I know.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 11-02-2013, 19:29
FRC #3929
Smile Re: Arduino Leonardo Recognized as Joystick
The error had a simple solution. We just had to go to Tools, then Serial Port, and select COM5. Once there was a check mark next to COM5, the Arduino Leonardo showed up on the Driver Station as a joystick.
