Go to Post I can still remember how weird it was to look on the other side of our booth and see a kid in a suit tossing purple balls... - OneAngryDaisy [more]
Unread 11-02-2013, 20:39
AquaMorph's Avatar
AquaMorph AquaMorph is offline
Alumnus and Mentor for 2059
AKA: Christian Colglazier
FRC #2642 (Pitt Pirates)
AquaMorph is on a distinguished road
Vision Tracking with the AXIS M1013 Camera
We are using the AXIS M1013 Camera this year. I was looking at the difference between the cameras and the lenses are different. I tested out the vision tracking on a 50% scale model and the distant is not accurate. Is there something I have to adjust for this new camera?
FRC Drive: Play Store FRC Manager: Play Store
Unread 11-02-2013, 20:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Vision Tracking with the AXIS M1013 Camera
Yes. http://wpilib.screenstepslive.com/s/...-compatibility
Unread 12-02-2013, 19:32
AquaMorph's Avatar
Originally Posted by Joe Ross View Post
Ok I can't figure out how to change it.
Unread 12-02-2013, 20:20
I believe the distance calculation is the only place the angle is used. You can either update the enum and array and set the correct value, or you can delete the wires that index the array and simply wire in your robot's angle.
Greg McKaskle
Unread 12-02-2013, 20:26
AquaMorph's Avatar
Greg McKaskle
The distance is the only thing off and I would like to get it correct. I can't figure out how to change the camera angle. I have looked at the Distance.vi and haven't found where to change it.
Unread 12-02-2013, 20:42
The attached image shows how to ignore the array and selector and hard-wire your camera lens angle. I didn't check the number BTW, so use the right angle in place of the 67. Note that the numbers used by the example are just a bit different than what the camera mfgr published. These were determined with a calibration routine.
Greg McKaskle
Unread 12-02-2013, 20:53
AquaMorph's Avatar
Greg McKaskle
Thanks that worked. I found the right number to be 62.
