Go to Post All the powerhouse teams will be having powerhouses dinners with each other in the powerhouse restaurants, probably. - T^2 [more]
Unread 11-02-2013, 21:02
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
Rookie Year: 2011
arithehun is an unknown quantity at this point
CAN Voltage Control
So, I am trying to control a motor using the voltage model so I can set the ramp rate to about a 10 second build-up. However, the output seems to be null. Even the indication light remained a solid yellow. Everything works perfectly over VBus in this configuration.
Code:
shootingMotor = new CANJaguar(leftMotorId, CANJaguar.ControlMode.kVoltage);
setVoltageRampRate(0.10);
shootingMotor.setX(12);
