Go to Post The problem with anecdotal evidence is that you never seem to get the whole anecdote. - Lea DeFoote [more]
Unread 12-02-2013, 10:55
ChristianSalgad ChristianSalgad is offline
FRC #3354
ChristianSalgad is an unknown quantity at this point
Deploying Robot Code / Vision Example
Hi,
I'm trying to integrate Vision Example "Rectangle Target 2013" to our Robot Main, I think I have successfully done it, however when trying to deploy the code to de CRio I get the following error:
LinearAveragesNI_Vision_Development_Module.lvlib:I MAQ LinearAverages loaded with errors on the target and was closed.
LabVIEW: Failed to load shared library nivision.*:LV_LinearAverages2:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
Deployment completed with errors.
I then tried deploying ONLY the example code... getting the same error message.
Any idea of what we should do?
Unread 12-02-2013, 11:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Deploying Robot Code / Vision Example
Did you configure your cRIO for LabVIEW using the Imaging Tool?
Unread 12-02-2013, 12:12
FRC #3354
Yep, we did that, however we will try it again later today.
