Go to Post You know you're addicted to FIRST when you text your mentors more than your friends from school. - LindsayC [more]
Unread 12-02-2013, 12:04
ed91694 ed91694 is offline
FRC #3082
ed91694 is an unknown quantity at this point
Issues with the Talons
Our team has been procrastinating a lot on our robot. We just got electronics board finished, but the talons don't seem to work. When we tried taking the robot for a drive, the talon lights blink red and green, which suggests that its getting the PWM signal right, but there is no output going through the Talons.
Any suggestions on how we can get this fixed? We are running out of time and I really appreciate any help we can get.
Unread 12-02-2013, 12:22
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Issues with the Talons
Was the power input ever wired up backwards? That will fry them.
We had one wired backwards, and it blew, but the lights still worked as if there was no problem, but there was no motor output.
Mike Copioli said they were updating the firmware so the light sequence changes when this failure happens, not sure when this hits, or hit production units.
I don't know if there is a way to test for this condition. Send an email to support@crosstheroadelectronics.com Mike was very responsive.
Scott.
The sooner we get behind schedule, the more time we have to catch up.
Unread 12-02-2013, 12:29
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Make sure your PWM cables are plugged in, and in the correct orientation. Also ensure the ribbon cable from your digital sidecar to your crio is secure.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 12-02-2013, 12:34
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Since the lights are flashing red and green that means it is getting a signal to drive. Make sure you are putting in a large enough signal or it won't actually have enough power to turn it. Also make sure if you have two motors on one gear box that the two aren't driving against each other.
Unread 12-02-2013, 13:24
petet4 petet4 is offline
AKA: Pete Thomas
FRC #0706 (Cyberhawks)
petet4 is on a distinguished road
Not sure what language you are programming, in C++ we selected the Victor class when controlling the Talon. The lights would blink as you mention, so assumption was it was getting the PWM signal, but motor speed was erratic.
Discovered the problem, the Talons require a faster PWM update rate of 333Hz (user manual sec 13, page 14), whereas the Victor is a 50Hz update rate. Selecting the Talon class fixed the problem and all was good.
-pete
Unread 12-02-2013, 13:25
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
No ,they do not require a faster update rate. They are capable of that update rate.
Unread 12-02-2013, 13:56
AKA: Pete Thomas
I will confirm PWM update rate this evening with a scope between Victor and Talon class.
Here are the spec's for the Talon
Input voltage 6-28 VDC
Continuous current 60 A
Peak current 100 A
Input PWM signal 1-2 ms @ 333 Hz
Input resolution 10-bit (1024 steps)
Output resolution 10-bit (1024 steps)
Output switching frequency 15 kHz
I read this as 333Hz is the update rate as it does not ready provide a lower range for the update. Then kind of assumed it was the update rate.
Now a little puzzled as why changing to the Talon class fixed our issue. Looking at the C++ source code for both the Victor & Talon I expected to see something with the update rate but did not. The only thing were slight changes in the PWM bounds for full forward, reverse and dead band ranges.
Boy, just when you think you have answer you have to go back and dig a little deeper to fully understand.
-pete
Unread 12-02-2013, 14:41
FRC #3082
Thanks for the quick responses!!!
We know for sure that there is no output going through... I tried using a voltage tester and absolutely nothing goes through.
I remember that when testing out the electronics board for the first time, we didn't realize the power board polarity was switched and we turned on the breaker with 6 talons plugged in I didn't know this could have damaged the talon, since the lights were still blinking. I will email CTR Electronics to figure out how to test them. Thanks everyone!
Unread 12-02-2013, 14:53
Ether's Avatar
Rookie Year: 1969
2013 Java WPILib drives the Jag input PWM at 5ms (200Hz), Victor at 10ms (100Hz), Talon at 10ms* (100Hz),
and servo at 20ms (50Hz)
Code:
    private void initJaguar() {
         * Input profile defined by Luminary Micro.
         * Full reverse ranges from 0.671325ms to 0.6972211ms
         * Proportional reverse ranges from 0.6972211ms to 1.4482078ms
         * Neutral ranges from 1.4482078ms to 1.5517922ms
         * Proportional forward ranges from 1.5517922ms to 2.3027789ms
         * Full forward ranges from 2.3027789ms to 2.328675ms
        setBounds(251, 135, 128, 120, 4);
        setPeriodMultiplier(PeriodMultiplier.k1X);
        setRaw(m_centerPwm);
    private void initVictor() {
        setBounds(208, 131, 128, 125, 54);
        setPeriodMultiplier(PeriodMultiplier.k2X);
    private void initTalon() {
        setBounds(211, 133, 129, 125, 49);
    private void initServo() {
        setBounds(245, 0, 0, 0, 11);
        setPeriodMultiplier(PeriodMultiplier.k4X);
* note: the Talon can be run at 5ms period, if you wish, by changing the period multiplier to k1X (like the Jag)
