Go to Post If I had a dollar for every time I thought we'd get a legitimate hint....Well, I might have a few dollars... - Andrew Blair [more]
Unread 12-02-2013, 12:45
Ajfirst's Avatar
Ajfirst Ajfirst is offline
FRC #3218
Ajfirst is an unknown quantity at this point
Battery
Hello again
I am from team 3218 and I had a question about batteries on the robot.
Are we allowed to put an extra battery on the bot if it is only being used as a counter balance to counter the weight from the battery being used for power? the battery would not be connected to anything and would not be any extra power
Thank You
Unread 12-02-2013, 12:51
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Battery
I would not use a battery as a counter-weight. Find some chunks of steel and use those instead.
I cannot quote a specific rule from the manual saying you can't but I would advise against it. With the leads of the battery or the anderson connector not connected to anything, it would create a potential safety hazard.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 12-02-2013, 13:06
dudefise dudefise is offline
FRC #2637 (Panthers)
Rookie Year: 2011
dudefise is an unknown quantity at this point
Re: Battery
I concur with the above Wiifi's opinion on the safety rules. I do not think that it would be safe, as exposed wires could short. You could also damage the battery!
Using a giant brick of steel (or some other material) would be safer and better.
I did some quick calculations and a battery-sized piece of steel would weigh about 40lbs, which is heavier than the battery iirc. This means you could use a smaller piece of steel, or have a heavier (and possibly more effective) counterweight.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 12-02-2013, 16:28
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
Rookie Year: 2011
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Re: Battery
I agree with everything that was already stated.
I suggest that you go to Goodwill or some other thrift shop and buy some free weights. They always seem to have a few random pieces around. Used sporting good shops also sometimes sell extra unmatched weights individually for a modest price.
The advantage of using weight lifting weights is that if you buy them in small weight units the weight will be easily adjustable. They are also more compact, and they come with a convenient mounting hole.
This is the zeroth day of the rest of your life.
Unread 12-02-2013, 17:00
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Battery
There's a picture floating around here of a robot with free weights attached to it. I can't remember the competition or the year but I remember seeing it...
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 12-02-2013, 19:22
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Battery
I remember seeing a robot with an arbor press attached to it as ballast..
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 13-02-2013, 04:41
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: Battery
I think that may have been my doing... >.>
I was on MOEbile pit and the team's robot was so light their wheels has almost no traction. I used their pit vice as the clamp to attach the press to the frame for even more weight
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 13-02-2013, 08:18
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Battery
Aj,
One and only one battery is permitted on the robot, see R34. Other battery types are allowed if and only if they are part of a COTS computing device or enclosed camera. Weight may be added provided a few items are met.
Free weights, steel plate, vises, etc. must be firmly attached to the robot. Ty-wraps, tape, wire, twine or rope, etc. do not meet the "firmly attached" definition. Attachments can be appropriate hardware, welding, etc.
As to lead, it must be entirely painted or sealed prior to attending an event. It may not be machined at the event.
As to other types of weight, notably shot, sand, liquid, etc., this must be enclosed in a container that will not spill or crack open with the forces normally encountered on the field. More than once, teams have added these items and we spent considerable time cleaning the residue from the field.
Considering the nature of the game, if you climb, it seems that additional weight would work against you.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 13-02-2013, 12:28
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Battery
Originally Posted by Al Skierkiewicz View Post
One and only one battery is permitted on the robot, see R34....
R34 actually says:
The only legal source of electrical energy for the ROBOT during the competition, the ROBOT battery, is one of the
following 12VDC non-spillable lead acid batteries:...
I'm not saying that using a battery as ballast is a great idea, but is it automatically ruled out by R34? If the ballast battery has nothing connected to its leads, then it's not a source of electrical energy for the ROBOT.
Of course, there are safety issues to be addressed, and I think there are better ways of adding ballast to a robot. But, I can't resist a good debate. I'm just saying I don't think the battery as ballast is inherently illegal.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 13-02-2013, 13:43
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
Re: Battery
That is why I didn't quote R34, it is debatable if the battery is not being used as an energy source. I think for safety's sake it should not be legal, and if you were to ask it on Q & A they would probably rule against you using it as a counter-weight.
Unread 13-02-2013, 16:50
Unsung FIRST Hero
Rookie Year: 1996
Re: Battery
Cal,
Please note that all references to the battery in the robot rules is in the singular, meaning one. This has been answered in the Q&A for several years in this fashion. However, I do not remember seeing that question asked this year. If there is still some confusion, someone should ask to remove all doubt.
Al
WB9UVJ
www.wildstang.org
Unread 13-02-2013, 19:06
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Battery
I would say that having an extra part of acid and lead is by definition unsafe. One is dangerous enough.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
