Go to Post You dont get paid based on your IQ, or how many things you have memorized, or what you can invent on your feet. You get paid for results. - KenWittlief [more]
Unread 12-02-2013, 14:15
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
Rookie Year: 1999
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Question How do I deploy code without WindRiver?
Here's my problem, the laptop with WindRiver installed is currently broken and a new one will arrive later this week. However, we want to actually operate our robot today. So, I need to get the .out file from my desktop at home on to the cRIO at the school. I know that I can FTP to the cRIO but when I did that yesterday I didn't know which folder to place the .out file in and I don't know if I have to rename it first. These are both things that I think I need to know for the purpose of making this work. I've done some searching but I haven't been able to find the answer anywhere else. Thanks for any assistance you can give ^_^
EDIT: I found the answer. The search function is kinda bad here on CD I found a thread from two years ago using Google just now. For future reference this is where it goes: ftp://10.xx.yy.2/system/startup/FRC_UserProgram.out Thanks go to byteit101 for helping someone else with this same issue.
Unread 12-02-2013, 21:31
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: How do I deploy code without WindRiver?
Glad the me from the past could help you now :-)
That ftp path still works, though if you want to also *build* code without WindRiver, you can use either UCPP makefiles, or the new GCC toolchain (http://www.chiefdelphi.com/forums/sh...d.php?t=105877 and http://www.chiefdelphi.com/forums/sh...d.php?t=109385)
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 12-02-2013, 23:39
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
The "deployment" is simply a ftp transfer to the robot. You can use any ftp client to do this (like filezilla). The name and password on the robot is "user" and "password". The default directory (on the robot) is the correct destination.
HTH
Fast, cheap or working - pick any two!
Unread 13-02-2013, 18:03
xraymypanda's Avatar
xraymypanda xraymypanda is offline
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
Rookie Year: 2011
xraymypanda has a spectacular aura aboutxraymypanda has a spectacular aura about
How my team does it:
In Windriver, Clean your code
Download Filezilla
Open Filezilla
Connect to the robot (10.te.am.2)
Navigate to/ni-rt/system/ on the cRIO
Navigate to C:/YourProject/PPC603gnu/YourProject/
Rename YourProject.out to FRC_UserProgram.out
double click on FRC_UserProgram.out to send it to the robot
Once the transfer is complete, reboot your robot and drive away!
2011: Head Scout
2012: (figure)Head Programmer
2013: Head Programmer, Chief Strategist, Outreach Executive, and Driver
Unread 14-02-2013, 16:43
CodeYeti's Avatar
CodeYeti CodeYeti is offline
FRC Addict
AKA: Matt Coffin
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2010
CodeYeti is an unknown quantity at this point
Somebody actually developed a tool for uploading images to the crio called frctool. It's written in go. If you're interested, the link is below. Obviously, this isn't the best solution if you're just going for a one-time upload.
https://bitbucket.org/zombiezen/frctool
Good luck!
