Go to Post My only question is, Can your robot place tetras and deliver Krispy Kremes to team mentors in autonomous mode? - Rich Kressly [more]
Unread 12-02-2013, 16:40
stephmak stephmak is offline
High King of Code--Lead Programmer
FRC #4621
Rookie Year: 2011
stephmak is an unknown quantity at this point
NetBeans Deploy Code Hang
Hi Everyone,
We finished our robot code, connected the Classmate computer directly to the cRIO via Ethernet cable, cleaned/built the code in NetBeans. We then told NetBeans to run/deploy the code, and it soon hung at the OTA Server stage. After researching the problem, I found that this was normal and we re-deployed the code, only for it to hang again, at the following two lines:
[cRIO]edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@15 entered connection status: GOT_CONNECTION_FROM_CLIENT
[cRIO]edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@15 entered connection status: CONNECTED_TO_CLIENT
We then canceled the process, after it stayed at the same line for a few minutes and tried driving in Teleop mode. The three lights for Communication, Robot Code, etc were all green but when the robot connected and we hit Enable, the area near the bottom left on the Driver Station told us there was no robot code and nothing on the robot worked. Our electronics people have double checked all connections, and have concluded that there is nothing wrong wiring wise. I have also been back searching here on Chief Delphi for a solution and have not found anything that worked so far. Can anybody give us a solution please?
Thanks!!
FTC
2011-2012 Bowled Over: Team #5165 Star Cygnus X-1
FRC
2013-2014 Ultimate Ascent: Team #4621 Yotta Robota
