Go to Post I swear, at IRI, Gary and I only talked about coming up with a plan to do away with Billfred, we didn't actually do anything... yet... - MissInformation [more]
Unread 12-02-2013, 18:41
progal's Avatar
progal progal is offline
Programmer
AKA: Shelby
FRC #0384 (Sparky)
progal is an unknown quantity at this point
Accelerometer Code Making Robot Stop Moving
Hey, apologies if this is an already answered question. I couldn't find anything on the topic.
The problem that we're having is whenever we state the accelerometer (not even doing anything with it, but just instantiating it), our robot components stop working completely. The robot won't move, et cetera.
Also, we don't know how to get the values from the gyro once in teleop, or rather the method to use to get the values from the accelerometer.
This is our code:
Code:
class RobotDemo : public SimpleRobot
        RobotDrive myRobot; // robot drive system
	Joystick stick1, stick2; // only joystick
	ADXL345_SPI adxl;
Code:
public:
	RobotDemo(void):
		myRobot(2, 1),	// these must be initialized in the same order
		stick1(1),		// as they are declared above.
		stick2(2),
		adxl(5, 6, 7, 8, ADXL345_SPI::kRange_2G)
Thanks in advance!
C++ Programmer
Unread 13-02-2013, 06:58
kenfox kenfox is offline
FRC #3322 (Eagle Imperium)
Rookie Year: 2013
kenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of light
Re: Accelerometer Code Making Robot Stop Moving
Originally Posted by progal View Post
whenever we [instantiate] the accelerometer ... our robot components stop working completely.
Code:
The constructor for ADXL345_SPI takes the digital IO module as the first parameter and has a default kRange_2G value for the 6th parameter. You are asking it to use a non-existant module #5 which probably causes the robot code to crash. Do you see an error message about using a module out of range?
If you only have one digital IO module in the cRIO, it will be module #1.
Does the following code work better?
Code:
adxl(1, 5, 6, 7, 8)
Unread 15-02-2013, 18:22
progal's Avatar
Programmer
AKA: Shelby
FRC #0384 (Sparky)
Code:
adxl(1, 5, 6, 7, 8)
It did work.. kinda. It gave us the values but after it showed us these values it didn't update after that:
X: 0
Y: 2
Z: 4
This is how we're getting the values:
Code:
dsLCD->PrintfLine(DriverStationLCD::kUser_Line4, "Accelerometer X: %d", adxl.kAxis_X);
dsLCD->PrintfLine(DriverStationLCD::kUser_Line5, "Accelerometer Y: %d", adxl.kAxis_Y);
dsLCD->PrintfLine(DriverStationLCD::kUser_Line6, "Accelerometer Z: %d", adxl.kAxis_Z);
Is this how we should be finding the values?
C++ Programmer
Unread 15-02-2013, 20:13
progal's Avatar
Programmer
AKA: Shelby
FRC #0384 (Sparky)
Apologies! We just edited our code to try and find values:
Code:
dsLCD->PrintfLine(DriverStationLCD::kUser_Line4, "X: %d", adxl.GetAcceleration(adxl.kAxis_X));
dsLCD->PrintfLine(DriverStationLCD::kUser_Line5, "Y: %d", adxl.GetAcceleration(adxl.kAxis_Y));
dsLCD->PrintfLine(DriverStationLCD::kUser_Line6, "Z: %d", adxl.GetAcceleration(adxl.kAxis_Z));
This gave us these values:
X: 21360244
Y: 21360244
Z: 21360244
And the values never changed. Is there a "reset" for the accelerometer? Any ideas?
C++ Programmer
Unread 16-02-2013, 00:58
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I thought %d was for integers. Doesn't the GetAcceleration() method return a float?
Unread 16-02-2013, 10:27
SushenaJammi SushenaJammi is offline
FRC #0384
SushenaJammi is an unknown quantity at this point
in ADXL345_SPI.h, it says
Code:
 virtual double GetAcceleration(Axes axis);
Unread 16-02-2013, 10:40
progal's Avatar
Programmer
AKA: Shelby
FRC #0384 (Sparky)
%d is for doubles
%f is for floats
%i is for integers
but the accelerometer values return a double as Sushena pointed out.
C++ Programmer
