Go to Post Winning or losing on the field has nothing to do with this success. - E. Wood [more]
Unread 12-02-2013, 18:58
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
CRIO Image tool won't recognize pneumatic breakout
when we run the Crio image tool, it does not recognize the pneumatic breakout in the slot. it always shows up red, like we have it in the wrong spot. We have tried all the spots. We think it belongs in slot 3. Any help would be great.
Unread 12-02-2013, 19:27
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: CRIO Image tool won't recognize pneumatic breakout
Yes, it should be slot 3. If you look at the cRIO slot 3 pins, do you see any damage? A bent pin would cause the module to not be detected.
Unread 12-02-2013, 20:27
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
+1 on the bent pin.
We had an issue last year and it recognized that something was there, but it wasn't sure and it caused all sorts of little problems. We found a single bent pin, which I repaired myself. Works great now.
Of course, if you aren't comfortable trying to bend the pin back by yourself, maybe find someone else who is or send it to NI to get fixed. It's kind of expensive if you make the problem worse.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
