Go to Post Also, after 3 years of FRC I finally hugged that Platypi! - That 281 Guy [more]
Unread 12-02-2013, 20:41
|DELTA|'s Avatar
|DELTA| |DELTA| is offline
Unregistered, CAD Junkie, Machinist
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2011
|DELTA| is an unknown quantity at this point
Smile Team 997 Spartan Robotics "Ultamate Ascent" Climber (vid)
This is team 997's Climber Bot. It has two pairs of pistons, and a linear actuator to move the inner pair forward and backward. I does not currently have any other method of movement, although a modular drivetrain "attachment" is planned and in the works. There is also going to be a "disc dumper" attachment on the middle pair of pistons. This dumping phase of the climb is simulated as a dry run in the video. You may notice that there is a lot of rocking, and that the robot is bashed against the pyramid. This will be alleviated by another pair bumpers on the chamfered front of the 'bot. Any questions, comments, or critiques? Please feel free to post!
http://youtu.be/9lqxi2BZlF8
|DELTA|
Unread 12-02-2013, 20:49
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
Team Role: Mechanical
Rookie Year: 2011
swwrobotics is an unknown quantity at this point
Re: Team 997 Spartan Robotics "Ultamate Ascent" Climber (vid)
It says that the video doesn't exist...
Unread 12-02-2013, 20:50
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
Rookie Year: 2007
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Speed needs to be greatly increased. Especially if you want to be a dumper as well.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 12-02-2013, 21:00
|DELTA|'s Avatar
Team Role: CAD
Rookie Year: 2011
Hmmm. I will look into the video problem. And, as to the speed issue, I also believe that we are pushing it at 2:09, but that was with multiple mistakes from the driver, and also other unnecessary stops, such as the aforementioned bumps. Also. We are planning to have the entire climb done in an "autonomous mode". That way, we will be approaching 100% repeatability. Also, in this video, I am not certain that the tanks were precompressed prior tho the climb. You may also note that it looses pressure on the way up. That would be due to this.
|DELTA|
Last edited by |DELTA| : 12-02-2013 at 21:08. Reason: Additional info needed, also, I forgot what I was doing.
Unread 12-02-2013, 21:01
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
I agree. You lose a lot of time just with the swinging. Is it possible that you could shape that end of your robot like a wedge so that you can immediately start pulling yourself up to the next bar? Hopefully the side of your robot would ride up over the rung.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 12-02-2013, 21:05
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Rookie Year: 2007
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
you might want to add some sensors/switches and programming to eliminate the need for a driver to control each action. i think that'll speed up the time and eliminate errors.
Unread 12-02-2013, 21:07
ENIAC's Avatar
ENIAC ENIAC is offline
AKA: Matthew Petersen
FRC #5958 (Blue Wave Robotics)
Team Role: Coach
ENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the rough
This should be the right link:
Unread 12-02-2013, 21:10
dodar's Avatar
Rookie Year: 2007
Even still, you should be at level 3 in at most 90 seconds; at least, if you want to be able to score in the pyramid goal. And 90 seconds is a very long time.
Unread 12-02-2013, 21:11
|DELTA|'s Avatar
Team Role: CAD
Rookie Year: 2011
Thanks, Mat.
|DELTA|
Unread 13-02-2013, 08:39
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Rookie Year: 2011
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Could be very worth it to use some gas springs to accelerate retraction of the cylinders.
Unread 13-02-2013, 09:08
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
Rookie Year: 2011
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
were there wheels on your robot because to me it just looks like a big white block on the bottom of the robot
Edit i now saw the part about a modular drive
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 13-02-2013, 09:12
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Amazing job on this thing. Really cool design.
Unread 13-02-2013, 09:24
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
Mentor
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Rookie Year: 2007
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
Nice work. As others have mentioned, the swinging is a problem, in that it is slowing you down. Perhaps you could deploy a pool noodle as a forward protrusion (either a loop or a stick) to impact the departed bar on the return swings and have a dampening effect on the swinging. Should not take much...just something soft and flexible to touch the crossbar and take energy out of each swing of the robot.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
Unread 13-02-2013, 12:22
With more storage tanks, more practice, and by charging your pneumatics beforehand I think you'll have some gain in speed but not too much. The step that I see which takes away some significant time is whatever mechanism you have to move your robot back and forth. For example, at the beginning of the hang, whatever you're using to pivot your robot up off the ground can probably be sped up. The actuation itself is not your issue, in my opinion. Putting a hard stop when you sway back and forth will also help significantly.
  #15   Spotlight this post!
Unread 13-02-2013, 12:36
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
I'll echo this. This will make your climb sooooo much quicker. Stick a light gas spring in line with your cylinders that will force the hooks up when you have no pressure retracting the cylinder. You will use half the air volume to climb, hopefully cutting your climb time in half!
Love the design, great work!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
