Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 12-02-2013, 21:40
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
Rookie Year: 2012
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
RGB LED strips on our Robot
At this point in the season, our team is ready to start making our robot look good. I recently found this kit: http://www.amazon.com/LEDwholesalers...bxgy_hi_text_y
Now, the main problem I have with this is that it is obviously a complete ruler breaker: We cannot control anything via IR. Does anyone has any ideas to remove this or simply set a color on an RGB strip? or, if you have a better idea for underglow/ perimeter lights, please post it here. Thanks.
Unread 12-02-2013, 21:54
ggorsuch ggorsuch is offline
FRC #2471 (Team Mean Machine)
Rookie Year: 2010
ggorsuch is an unknown quantity at this point
Re: RGB LED strips on our Robot
Our team purchased the same thing. They seem to "remember" the last setting they were on. So...theoretically, you could set them to what you want then remove the IR receiver.
Unread 12-02-2013, 22:14
jbsmithtx's Avatar
FIRST Fanatic
AKA: Josh Smith
Rookie Year: 2012
Are you saying that they "remember" in between power off times? Because that would work perfectly..
Unread 12-02-2013, 22:25
Jecht22 Jecht22 is offline
2012 Team President
AKA: John Springer
FRC #2522 (Royal Robotics)
Team Role: Mechanical
Jecht22 is an unknown quantity at this point
We used basically these exact LED's last year. Our solution was to just cut off the ir receiver and put a female pwm connector on one side that was cut off and a male connector on the other so we could re-attach the ir sensor if needed. This would allow you to still be able to change the light color/pattern between matches or change other settings. You could use any kind of connector really but we decided to just use pwm's because they are easy to use and we had a bunch of extras. And yes it does remember the last pattern that was selected.
Our robot last year
http://www.idleloop.com/frctracker/p.../2012/1469.jpg
http://www.edmonds.wednet.edu/cms/li...%20cropped.jpg
This is actually what I will be working on this weekend. I can give you more information on how to make everything work if you want or take pictures of my finished work on sunday or monday.
Unread 12-02-2013, 22:43
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Dioder led lights from Ikea work AMAZING.
http://www.ikea.com/us/en/search/?query=dioder
I'll try and upload a video tomorrow of the lights. Nothing I currently have does them justice.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 12-02-2013, 22:19
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Another solution would be to wire in the red and blue wires to an in-line manual switch.
