Go to Post Either this entry is the winner or Andy needs professional help. I can't quite decide which... - Rich Kressly [more]
Unread 12-02-2013, 21:43
bspymaster's Avatar
bspymaster bspymaster is offline
FRC #1732
Rookie Year: 2011
bspymaster is an unknown quantity at this point
Post reading and writing dashboard data
Hello.
I am currently working on the dashboard project for our team for the tournament. I am trying to send a string variable from the dashboard program to the CrIO to tell the robot which autonomous mode to run. I tried using the Smart Dashbord "SD Read String" vi in the robot code and using "SD Write String" in the dashboard, but it only sends the information to the code once, if the dashboard was turned on before the robot code was deployed. It never updates afterwards, no matter what I do, unless I redeploy the code. Both parts of the code are written inside of while loops. Any suggestions? Thanks.
Unread 12-02-2013, 22:03
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: reading and writing dashboard data
How are you changing the value of the string in the Dashboard?
Unread 12-02-2013, 23:07
bspymaster's Avatar
FRC #1732
Rookie Year: 2011
It is a dropdown string box (I forget what Labview calls it). the output from the control is a string. I'm plugging that string into a case structure in autonomous independent.vi.
Unread 12-02-2013, 23:20
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Does it show up correctly in the variables tab of the dashboard? Is the control also in a while loop, or just the write string vi?
Unread 12-02-2013, 23:35
bspymaster's Avatar
FRC #1732
Rookie Year: 2011
I never thought to check the variables tab. Good idea! The entire thing (including the control) is in the while loop. in the CrIO code, the entire thing is in a loop as well.
Unread 13-02-2013, 00:08
Software Architect
You probably don't need to do an explicit SD Write String with the control's value. Just putting a disconnected control on the Operation tab of the Dashboard is enough to share it as a SmartDashboard variable.
