Go to Post Its not the type of material you use, but how you use it... - jrocket567 [more]
Unread 02-12-2013, 11:06 PM
skidad68 skidad68 is offline
FRC #2506
skidad68 is an unknown quantity at this point
DigitalInput.Get() always returns zero
...well, almost always.
I'm using the IterativeRobot template and polling a DigitalInput within the AutonomousPeriodic() function.
I have a NO switch wired between GND and SIG on sidecar digital input #1.
The very first time through the loop, the call to Get() returns the correct value corresponding to the switch state.
Every time after that, it always returns zero, regardless of the state of the switch.
What is my issue, hardware or software?
Unread 02-13-2013, 12:00 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: DigitalInput.Get() always returns zero
Without seeing either your hardware or your software, it's impossible to say where your problem lies.
Unread 02-13-2013, 09:06 AM
FRC #2506
Does this help? The problem is in the DriveWheel::calibrate() method.
DriveWheel.h
Code:
#ifndef DRIVEWHEEL_H
#define DRIVEWHEEL_H
#include "WPILib.h"
class DriveWheel
    CANJaguar    driveMotor;
    CANJaguar    steerMotor;
    DigitalInput    limitSw;
    bool            calibrated;
public:
    DriveWheel(UINT8 driveID, UINT8 steerID, UINT8 limitID)
        : driveMotor(driveID, CANJaguar::kPercentVbus),
        steerMotor(steerID, CANJaguar::kPosition),
        limitSw(limitID),
        calibrated(false)
    void init();
    void calibrate(int clock);
    void setValues(double drive, double rotation);
#endif
DriveWheel.cpp
Code:
#include "DriveWheel.h"
#define LIMIT_ACTIVE 0
void DriveWheel::calibrate(int clock)
    int limit = limitSw.Get();
    printf("limit %d\n", limit);
    if (clock == 0)
        printf("start calibrate\n");
        if (limit == LIMIT_ACTIVE)
            calibrated = true;
        else
            steerMotor.ChangeControlMode(CANJaguar::kPercentVbus);
            steerMotor.EnableControl(0);
            steerMotor.Set(0.1);
    else if (!calibrated)
            steerMotor.Set(0);
            calibrated = true;
            init();
void DriveWheel::init()
    steerMotor.ChangeControlMode(CANJaguar::kPosition);
    steerMotor.SetPID(2000, 0.1, 0);
    steerMotor.SetPositionReference(CANJaguar::kPosRef_QuadEncoder);
    steerMotor.ConfigEncoderCodesPerRev(250);
    steerMotor.EnableControl();
void DriveWheel::setValues(double drive, double rotation)
    driveMotor.Set(drive);
    steerMotor.Set(rotation);
Unread 02-13-2013, 09:22 PM
FRC #2506
Problem solved.
Bad digital sidecar.
(Ugh! Hardware!)
