Go to Post Seasons are often made or broken in the first week of build season. 1114 wouldn't be repeatedly giving their strategic design seminar if it wasn't that important. - Knufire [more]
Unread 12-02-2013, 23:52
Tyguy56 Tyguy56 is offline
FTC #3385
Tyguy56 is on a distinguished road
Question [FTC]: [FTC] putting two selector values in a case structure
I'm trying to put two selector values in a case structure so they work together for example, when using a button event how would i change the case structure so that a motor would not move until i pressed two buttons such as pressing buttons 7 and 8 to move a motor. i currently only know how to have it set to one button but as our mechanisms can only be deployed once i want to program it so it will only deploy after pressing two buttons h ow would i do this?
Unread 13-02-2013, 10:01
l0jec l0jec is offline
l0jec has a spectacular aura aboutl0jec has a spectacular aura about
Re: [FTC]: [FTC] putting two selector values in a case structure
How were you planning to use case statements for button presses even without the two button scenario?
I ask because the different buttons being pressed are not mutually exclusive and it is not clear to me what value you'd even be switching on.
You may be better off using if/else statements for the logic you've described?
Unread 13-02-2013, 11:03
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
Team Role: Leadership
ferret_guy is on a distinguished road
you can use boolean operators like this,
if ((button(7)&&button(8))=true)
then{ do stuff}
else
go on with life
Unread 13-02-2013, 17:12
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
The attached snippet should do what you are asking:
Name:	two button.png
let tau = 2pi
