Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
Unread 13-02-2013, 22:06
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Question Motor Drivers
Would it be possible to create a SLAVE circuit to the cRIO to control the small servos or even the motors, to prevent lag. I have an eight core processor that I could use to do all the dirty work...Just note, this would be for next year. not this year...no time
Unread 13-02-2013, 22:08
AKA: null
Rookie Year: 2012
Re: Motor Drivers
The processor is a P8X32A, in the form of a DIP-40 chip. I will try to migrate this into a QFP or a QFN
Unread 14-02-2013, 14:27
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Re: Motor Drivers
In addition to all the issues that Andrew has raised, I should point out that drawing the schematic is the "easy" part. Laying out a circuit board for a processor like this would require that you have experience designing (properly) multi-layer, high-speed circuit boards with multiple power and ground layers. There are no secrets or black art involved, just years of study. Learning to use the free Altium package only makes you a CAD operator, not a PCB designer. If you do not understand the difference, you are unlikely to design the circuit board properly, leading to "anomalous" operation that will make you tear your hair out. It is also likely that you will have a lot of trouble properly soldering the QFP and QFN packages.
It may be best if you do some research and find out what external processor boards other teams have been using to do their vision processing and buy one of them. It is likely that you will pay much more for just a bare PCB than you will for one of these fully functioning, mass produced processor boards.
Unread 14-02-2013, 16:50
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Motor Drivers
Excuse my bluntness, but the Propeller doesn't come within spitting distance of the cRIO. The PPC in the cRIO runs at 400MHz and can execute up to 3 instructions per clock - theoretical peak at 1.2 Billion instructions per second. The propellor has 8 cores at 80MHz, but takes at least 4 clock cycles to execute a single instruction - theoretical peak of 160 Million instructions per second. Note: Those are theoretical peaks, neither will sustain that throughput with actual code.
Then look at the quality of the instructions the two processors provide - The propeller doesn't even have hardware support for multiply, the PPC has a full fledged floating point unit and multiple integer units.
Once you add the cRIO's FPGA, it is a "brought a twisty straw and wadded up paper to a battleship fight" scenario.
Adding a propeller to your robot will provide no measurable benefit.
Unread 14-02-2013, 17:31
AKA: null
Rookie Year: 2012
Exclamation Re: Motor Drivers
I am pretty sure that vxWorks (on the cRIO) uses a lot of the processing power itself, just like how a slow netbook might have a 50% processor usage, running nothing but the operating system.
Unread 14-02-2013, 17:47
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Motor Drivers
Even if you cripple the cRIO to only a quarter of the specs Eric provided*, it's still no contest. 1/4 of the cRIO's specs still beats the Propeller, and that's without the FPGA, which does a lot of the heavy lifting in FRC. I still don't understand what you expect to gain.
*I'm not an expert, but that sounds unrealistic under normal circumstances or even heavy FRC usage.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 14-02-2013, 18:26
AKA: null
Rookie Year: 2012
Question Re: Motor Drivers
The system I am currently designing is supposed to be modular, kind of like the cRIO. an ADC breakout, PWMPAL Breakout are what I am wanting to create. The modules can easily be swapped, taken out, or be changed in order.
Unread 14-02-2013, 18:29
AKA: null
Rookie Year: 2012
Re: Motor Drivers
By the way, What I was asking is if the propeller could do continuous processing, especially when the cRIO is busy. I was thinking about using a Raspberry Pi, but the problem I thought is that it draws lots of power, and you cannot just remove the power plug to shut it down.
Unread 15-02-2013, 14:09
Mentor
FRC #2587
Rookie Year: 2011
Re: Motor Drivers
Devyash
You are attempting to do something that is pretty complicated and difficult. In order for you to be even moderately successful, you will have to climb up a very long and steep learning curve. The first thing you must learn is to realize who around you possess the knowledge that you need. Next, you must learn to listen to those people and to take their advice. It is pretty clear to me that the other posters in this thread have extensive experience in evaluating and selecting microprocessors.
I am in a STEM program and I have teachers that help me with these problems.
If your teachers have extensive experience doing this kind of work, then they can help you. Otherwise, you all have the opportunity to experiment and learn together. I must say that in the last 30 years, I have never seen a fresh (university) graduate who had the required skills to design such a PCB. Maybe one of the other people posting here have but it is probably pretty rare. Regardless, the kind of PCB you need should not be your first PCB design project.
This is a very admirable goal but making it modular is going to make an already difficult task many times more difficult.
Unread 15-02-2013, 18:00
AKA: null
Rookie Year: 2012
Re: Motor Drivers
I completely agree. However, another reason why I like this product is because it is cheap. I can go down to a store and get it for $8 plus tax (~$8.08 per chip) that means that we can add more processors if we need and that we dont need to worry too much if we fry a chip. If possible, I would be using a Raspberry Pi with a completely trimmed down linux kernel. However, this processor will take 300mA at a max, with all outputs high (or low) and driving something. I agree that I don't have as much knowledge and experience as a professional, as I am only a high school freshman, but I use AutoCAD Electronics, and I am pretty sure it tries to create the most efficient route as possible. Currently, the biggest problem is that I cant build a PCB with mor than two layers. However, There is something similar, called the HoverFly Pro, that uses a lot of the same technology.
Unread 15-02-2013, 23:08
Mentor
FRC #2587
Rookie Year: 2011
Re: Motor Drivers
As I have stated previously, this should not be your first design project.
A microprocessor board like what you are contemplating will require 4-6 layers. I have seen examples of such boards done in 2 layers with much less demanding processors than what you are using and they ended in grief. They were ultimately redone in 4 layers.
There are parts of the circuit where it is very unwise to use an autorouter. The real art in PCB layout is in where you place all the components, relative to each other, based on their function. Only then can you get effective and efficient trace routings. CAD programs are only tools for running traces. You still need to know why a trace should be routed in a particular way before running the trace.
Have you priced all the other components that you will need? The bare board will cost you somewhere around $50 from a reputable prototype manufacturer. I am skeptical that you can make a useable board that will take the QFP packages yourself due to the fine pitch of the pins.
Engineering is solving problems by making wise choices. If you want vision processing, you will have to pay a price, one way or another. It may mean paying some money and/or calculating your current consumption and making adjustments in your overall robot design.
Unread 18-02-2013, 22:58
AKA: null
Rookie Year: 2012
Lightbulb Re: Motor Drivers
Would it be possible to use the fpga to do all the io processing while the powerpc is doing the image processing and instruct the fpga. after talking to my pltw teacher, he told me that an fpga can do parallel processing continuously.
Unread 19-02-2013, 00:09
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Re: Motor Drivers
If your OS uses 50% of your CPU you need a new OS. vxWorks isn't that bad. Heck, even Windows isn't that bad.
But to reiterate the answer others have given to your original question: that kind of coprocessing is not legal for FRC; the cRIO has to control your motors. If you're experiencing lag you should spend the time to learn more about your current environment & find out *why* you have lag. It's pretty easy to introduce unwanted lag via programming.
Mentor http://www.teamtitanium.org/
Unread 19-02-2013, 12:10
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Re: Motor Drivers
Not only can someone do this, I already have a Parallax Propeller powering a brushed DC motor control and it does CAN with a Microchip transceiver. That controller is not a FIRST allowed part and can not be used on a FIRST robot without review by FIRST which at this time I have no reason to do.
I also constructed a robot control system with Parallax Propellers at the heart (plural if you like).
There are other people out there with plenty of experience that share your interest though please keep in mind that FIRST does retain the rights to ultimately decide what is on your FIRST approved robot and at this time you'll require far more than a working prototype to achieve what you desire.
So far as I know you can use the Parallax Propeller as a co-processor to the cRIO per the custom circuit rules, but these circuits as others have said, may not operate the motor outputs themselves. So you can't put the motor controllers, hobby servos or even relays on your Parallax Propeller board I/O. You could plug the Parallax Propeller board into the cRIO via the digital side car to...for instance...create a port for an SVGA monitor (though I don't know if having the actual monitor on the robot on the field would be legal you'd have to investigate). I currently see no reason you couldn't interface sensors to the Parallax Propeller such that you could service it with the cRIO. I can see how it might have some value in that sense.
As to the rest....the Parallax Propeller is a very different design philosophy than is common to much of the rest of the microcontroller industry.
It is not realistic to compare the clock speed of the cRIO with the Propeller.
The entire concept behind the Propeller is parallelism. It does not implement interrupts, but it does implement timers and PLL. It also implements shared memory space and common access to that shared memory and I/O using a round-robin fixed timing system.
The Propellor 1 for better for worse is very sparse on peripherals.
This means less idiosyncrasy in the integration.
However that means more glue and extra hardware (which can lead to cost but also to flexibility).
I come from a background of parallel computing using CPUs in mainframes.
To me for some applications the raw parallel nature of the Parallax Propeller makes a heck of a lot of sense when the target system parameters get unspecific.
I also have experience and close ties with Atmel, Microchip, Intel and Motorola. If you know the parameters of your project specifically sometimes it makes the best sense to use a microcontroller / microprocessor that is most closely designed for that purpose as compared to the Propeller which you can probably massage into that purpose.
As far as raw horsepower is concerned...there are plenty of things that a pile of Parallax Propellers can be tweaked to do that the purpose built cRIO would need to be redesigned for.
There is, at least to me, a comfortable middle ground where the Parallax Propeller is a real design option just as the ARM, the Atmel, and the PIC.
As far as the concerns about math, floating point, hardware support....virtually no student I have seen in FIRST is writing code for the cRIO in assembler. The ability to yield pure untainted performance is highly dependent on the quality of the byte interpreter or the compiler optimization. If you really need that kind of raw math performance there are many options including software and hardware coprocessors. One could debate the deciding factors on the impact for a very long time.
Obviously there is a very real limit in which the students will get lost in the large piles of minutia that will ensue.
  #15   Spotlight this post!
Unread 19-02-2013, 13:59
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Motor Drivers
The propeller has basically no peripherals. While that gives you a lot of flexibility in code, there are some things that should stay peripherals.
I work professionally with a MPC5600 series processor, which has a lot of peripherals. The eTPU (Time Processing Unit), eMIOS (Modular Input Output System), and DMA (Direct Memory Access) alone on the chip I am currently working with would take around 192 propeller cogs to get something close in functionality, and the TPUs also additional peripherals to synthesize clocks (e.g. angle clock/angle timestamp) and manage timestamps/clocks that would have to be replicated somehow. This dosen't include SPI, QADC or the actual PowerPC itself. While you could likely move some of the algorithms into the cogs that deal with the IO, you would basically need over 200 cogs to get the low and some mid-level software done, and we haven't even touched comm, OS, or high-level application code.
A good C compiler is basically a requirement for an embedded platform these days, especially with autocoding tools which generate C code from models.
Kettering Motorsports
