Go to Post I'd be more worried about getting struck by lightning right after winning the lottery. :p - evulish [more]
Unread 14-02-2013, 09:28
samirext samirext is offline
FRC #2576
samirext is an unknown quantity at this point
EP4 Encoder and Arduino
Hello there! , I'm having a little problems programming this encoder with arduino, i'm doing it manually (without a library) but it is not the best way to get the data.
I want to know if anyone of you have used it with Arduino or if you know how to get accurate data from the device, i need to obtain speed from a shaft. Your help is welcome ! Thanks!!
Best regards from Chile!
Unread 14-02-2013, 10:13
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: EP4 Encoder and Arduino
There are many ways to do it; the best solution depends on the specific application:
a) are you trying to measure speed or position?
b) do you care about direction?
c) how fast will you be spinning the encoder, and
d) what's the CPR of the encoder?
Unread 14-02-2013, 12:23
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Arduino Playground has some pretty well developed pages with code.
Need to start with Ether's questions, how many pulse/rev and what RPM rate you are looking to sense. Looks like many of the solutions use interrupts, which may be limited on the Arduino, so you may have significant limitations on rate it can process.
http://playground.arduino.cc/Main/RotaryEncoders
The sooner we get behind schedule, the more time we have to catch up.
Unread 14-02-2013, 13:35
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
There are several approaches you may consider, below is one I have used.
Using one channel of the encoder attached to one of the external interrupts and the other to a digital input. Use the interrupt service routine to determine the direction.
Each tick of the encoder will also represent a distance of travel or amount of rotation of a shaft. With those values known, you can calculate RPM and/or distance.
As mentioned by tr6scott, the Arduino may be somewhat limited on the maximum rate it can manage, so keep that in mind. How fast your Arduino can process interrupts will be directly related to how tightly you code your ISR.
Here is a piece of code I used to control the motor's rate. The motor directly drove the encoder. I use the Servo library to drive the motor because the signal generated is the same as the speed controller uses.
Code:
* Quadrature Encoder code using Interupt 0 (Dig pin 2) to *
* trigger ISR and accumulate count in variable "Accum"    *
*controlling servo(motor) on D9.                          *
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
const int COUNTPERREV = 128; // Encoder count per revolution
const int LOOPDELAY = 100;  //ms to delay the loop ie. 100 is 100ms
const int TARGETRPM = 1; // for testing, this establishes the RPM target RPM
long lastAccum =0;  // Holds the Accum count from the previous sample
int B = 5;  // Phase B pin connection
int pos = 90;    // variable to store the servo position
int desiredcount = (COUNTPERREV/TARGETRPM)/(1000/LOOPDELAY); // sets desired loop count
int errorAccum = 0; //this is added to neutral to position(drive) the servo(motor)
volatile long Accum = 0;  // Accumulator for total count
int rate = 0;  //measured # of counts per sample period
void setup(void)
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode (B, INPUT);  // Phase B pin type
  attachInterrupt (0, ISR0, RISING);  // Interupt 0 calls "ISR0"
   Serial.begin(115200); // connect to the serial port
  void loop (void)
    GetRate();
    errorAccum += (desiredcount - rate);  // adds difference between the desired count and the actual,
                                          // , the rate error, to be used to correct the motor speed
   myservo.writeMicroseconds(1500 + errorAccum);  // send servo(motor) control pulse
    Serial.print (" errorAccum is ");
    Serial.println (errorAccum);
    delay(LOOPDELAY);                       // waits the number of ms defined by LOOPDELAY
  void ISR0(void)
    if (digitalRead(B) == HIGH)
      Accum ++ ;
    else
      Accum -- ;
  void GetRate (void)
    long samplediff;
    samplediff = (Accum - lastAccum);  // Creates the counts since last sample
    lastAccum = Accum;  // Saves the count for the next loop
    rate = (int) samplediff;  // Cast the sample to an int and sets rate
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
