Go to Post Wait...you're supposed to have a driver? I guess I should have read past the Autonomous section in the manual :D - ASD20 [more]
Unread 14-02-2013, 11:25
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Quick Jaguar Question
My Team and I were testing our shooter yesterday and we forgot to take off the tape on the jaguar. It's a black jaguar from last year I believe. It after a while of testing it stopped working and started to blink a slow red light. Did we fry it or did it over heat or did we blow our mini cim?
Unread 14-02-2013, 11:34
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Quick Jaguar Question
Did it continuously blink or did it blink just a few times?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 14-02-2013, 11:43
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Rookie Year: 2011
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
From http://www.ti.com/lit/ug/spmu131a/spmu131a.pdf
A slow flashing Red LED indicates that the MDL-BDC24 detected one of the following fault
conditions:
„ Power supply under-voltage
„ Over temperature
„ Over current
„ Limit switch activated in the current direction of motion
When a fault condition occurs, the motor shuts down and the LED indicates a fault state during the
fault condition and for 3 seconds after the fault cause is cleared (except for the limit switch fault, which is cleared instantly). A slow flashing Yellow LED indicates that the MDL-BDC24 is not
receiving a valid control signal.
So, it may have shutdown due to over temperature.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 14-02-2013, 11:44
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Team Role: Leadership
Rookie Year: 2012
Toa Circuit is an unknown quantity at this point
From a PDF on the Jaguar, a Slow Flashing Red light is "Voltage, Temperature, or Limit Switch fault condition"
The Jaguar overheated and sensed that this was the case, so it shut itself off to prevent damage.
Simply let it cool down, take off the sticker, and you're good to go.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 14-02-2013, 11:47
When ever we tried to send a signal to the jaguar it blinked red. And lets hope it just over heated -_-
Unread 14-02-2013, 12:07
Moriarty's Avatar
Moriarty Moriarty is offline
AKA: Brendan Moriarty
FRC #4302 (Robophins)
Moriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to behold
Is your actual shooter mechanism experiencing a lot of force (stuck mechanisms, bearings, anything that could put excessive force on the motor)? Slow red blinking can mean an electrical fault (electricity being lost somewhere on the way through the Jaguar) or an over-current (too much electricity coming from the Jaguar). If your jaguar is blinking red every time you try to use your shooter something could be stuck or the jaguar could be broken (electricity not flowing through it correctly due to a problem created by overheating).
On a side note: Could someone please reinforce / verify my explanation of over-current and fault (I am not too experienced with electronics and would love if someone could give an excellent explanation of the two)
Unread 14-02-2013, 13:05
So we could have stalled our mini cim and blew that?
Unread 14-02-2013, 13:11
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
I doubt you blew the mini-cim. Most likely you just over-heated the Jag and the safety was enabled. Let the Jag cool, take that sticker off and test again.
Unread 14-02-2013, 13:55
Ok ty all for the advice i will get back to this post later tonight to update you guys
