Go to Post Off time, at a regional? What is that? - DonRotolo [more]
Unread 14-02-2013, 12:40
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Team Role: Leadership
Rookie Year: 2011
Reggie335 is an unknown quantity at this point
Air Cylinders
Is it Okay to order Air Cylinders On Amazon????
Unread 14-02-2013, 12:54
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Air Cylinders
As long as they meet all other requirements for pneumatic cylinders, then yes. If you're ordering them New (not Used) then it's a pretty safe bet they'll be COTS cylinders and thus legal.
Unread 14-02-2013, 13:04
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Air Cylinders
You may also wish to check Mcmaster.com for prices and delivery window. Its unlikely they are cheaper than amazon but they might be able to get it to you tomorrow if you absolutely need it.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 14-02-2013, 14:00
AKA: Reginald
Rookie Year: 2011
Re: Air Cylinders
Also how do i control two Air Cylinders At the Same Time?????
Unread 14-02-2013, 14:02
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Air Cylinders
If they are the same size and used in the same mechanism, you can put a tee fitting in the output of the solenoid to make both actuate at the same time.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 14-02-2013, 14:14
AKA: Reginald
Rookie Year: 2011
Re: Air Cylinders
Do i use a Single Or Double Solenoid??
Unread 14-02-2013, 17:29
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Air Cylinders
It depends on the cylinder, but most cylinders have 2 air inputs, so a Double Solenoid would be appropriate.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 14-02-2013, 18:24
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Air Cylinders
That's not correct.
The number of cylinder ports do not determine if a single/double solenoid is used.
Both single and double solenoids perform the same actions and have the same number of available ports.
They actually use identical bodies, but the double replaces the return spring with another energizing coil.
Why we choose one over the other has to do with how their behavior differs.
A single solenoid has a spring return to a home position.
It is energized to move it to the opposite position and will automatically return to it's home position when the energy is taken away.
  • One advantage is that it only takes up one solenoid breakout output, so you can have 8 single solenoids on one Solenoid Breakout and therefore control twice as many cylinders as an equivalent Breakout full of double solenoids.
  • An advantage might be that, went the robot is Disabled, the solenoid will return to it's home position, e.g., your robot just made it to the bar and hooked on, but the match ended before you could pull up, if you set the home position right it will still retract upon being Disabled and get you that 10 pts for hanging.
  • A possible advantage is that the robot automatically returns to it's starting configuration, so no hooking up after the match before it fits back on the cart.
  • A disadvantage might be that same home position when Disabled. Instead of stopping the robot cold when Disabled it may unexpectedly shift positions. E.g., if you're holding an arm up in the air with a cylinder, and someone (me) goes to look at something under the arm and a helpful person quickly Disables the robot for safety, then the home position could bring the arm snapping down onto said person's head (me).
A double solenoid does not have a home position.
It stays in whatever position it was last ordered to.
  • An advantage is it does not have to be kept energized once the move has been completed, although the energy savings is miniscule.
  • An advantage is that remaining in position is generally safer when the robot becomes Disabled unexpectedly. On the other hand we should Disable the robot before we get close to it anyway.
  • A disadvantage is it takes up two Solenoid Breakout outputs for the same functionality as a single, so only 4 fit can be controlled by a Breakout.
  • An advantage is that doubles have been donated for free to the KOP for a couple of years, and free is good.
