Re: Vex 2-Wire Motor 393
A complicated way that we are doing is drilling a hole large enough for the vex shaft into the end of the bolt. Then using a 1/2 in shaft collar we drilled and threaded holes in the shaft collar so we could connect a vex lock bar to the collar. then we slid the vex shaft into the end of the 1/2 shaft through the lock bar and used mini vex shaft collars to hold the vex shaft to the lock bar.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
