Go to Post AndyMark has done something amazing. - Sam390250 [more]
Unread 14-02-2013, 19:14
AutoBotAM AutoBotAM is offline
AKA: Christian Reese
FRC #2077 (Laser Robotics (Laserbots))
Rookie Year: 2010
AutoBotAM is an unknown quantity at this point
Can't access cRIO module 2
We have a cRIO module in slot 2 that connects to our digital side car, which connects to our victors. I have simple code that creates a Victor object and sets it to new Victor(2, 2) for slot 2 and channel 2, and just does .set(0.25). Yet nothing happens, and the Victor continues to blink. When we try to run it we get an error that it can't access module 2. Yet when I go into the cRIO imaging tool it is identified and OK. We so far have replaced the module, the sidecar, and the victors, with no avail. My future plan is to replace the battery, and the cable connecting between module and digital sidecar.
Has anyone else had an issue like this? Any fixes/advice?
EDIT: Alright, after a bit of research I found that one must do new Victor(1, 2) to access slot 2 on the cRIO. I'll try that next time I'm there, but I also tried new Victor(2) with no luck. Isn't that the same thing as new Victor(1, 2)? The only difference from new Victor(2, 2) is that it doesn't complain about there being no module.
"Mecanum drivetrains, like every other, have advantages and disadvantages, but some of the disadvantages being discussed here are overstated and/or misinformation." -buchanan
