Go to Post FIRST is not about building robots, it is about building people; the robots are just a good way to get the people there. - JamesBrown [more]
Unread 14-02-2013, 21:35
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
Rookie Year: 2011
MrRiedemanJACC will become famous soon enough
Shooter pointers
So I was wondering if a few teams can give us some pointers on the shooters? We are starting to attempt to get more distance, but still have some things to work on. (We are shooting 36 ft to the low goal - yet to try the upper goals -we are just getting started .
We have two pneumatic wheels and are a straight shooter. The second wheel is 25% faster than the first via chain and sprocket and we are using two bane bot 550's for shooting through the bane bot cimulator gearbox. We currently have compression to 10.5 inches from the shortest point on the wheel to wall. The frisbee sits lower on the wheel though so we are not getting that much compression. We have wheel tread material opposite the shooter wheels for grip. I forgot to download any pics, but will do that tomorrow.
So any hints teams have found to get their shooter further and or more accurate that we should be looking at?
Unread 14-02-2013, 22:18
OWilliamson's Avatar
OWilliamson OWilliamson is offline
FRC #2594 (NASKCO)
Rookie Year: 2012
OWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of light
Re: Shooter pointers
Did you design your shooter so that the wheels can be adjusted in and out to change your compression? Another idea is to change the psi in the wheels because we have a similar design that we can move are wheels and our psi is very low somewhere around 10 psi and we are shooting into the top goal easily.
Unread 14-02-2013, 22:35
Rookie Year: 2011
We can move them in and out easily. We can also move the height of the frisbee up by attaching slide plates to the bottom of the shooter tray.
Unread 15-02-2013, 22:41
DonRotolo's Avatar
Back to humble
FRC #0832
Then do that and see what happens.
Our pneumatic wheels have no air in them (~0 PSI).
Unread 16-02-2013, 11:38
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Wouldn't that be 14.7 PSI?
Unread 16-02-2013, 11:54
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
He meant 0 PSIG, which is what is usually used to measure tire pressure.
