Go to Post If the GDC made a game that consisted of driving in a straight line, it would probably be the hardest game in FRC history. - themccannman [more]
Unread 15-02-2013, 00:35
Evan-inc.
Posts: n/a
pic: look at that!
Unread 15-02-2013, 01:00
Andrew Lawrence
Posts: n/a
Re: pic: look at that!
Do you even fit within the 54" cylinder???
Unread 15-02-2013, 01:04
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Is this even legit?
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 15-02-2013, 01:37
Shane 2429 Shane 2429 is offline
FRC #2429
Shane 2429 is infamous around these partsShane 2429 is infamous around these parts
Unhappy Re: pic: look at that!
There is no way that fits in the 54in cylinder considering that length of that bar at 68 degrees (i think) is 32in between each lifting bar so if you are on the ground and passing the second bar you must be at least 64 in
Unread 15-02-2013, 02:01
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
I measured yesterday and yes it does fit. With a few inches to spare.
Unread 15-02-2013, 02:03
Twins Inc.'s Avatar
Twins Inc. Twins Inc. is offline
wait....are you a twin??
AKA: Zach Larson
FRC #2605 (Sehome Seamonsters)
Team Role: Leadership
Rookie Year: 2011
Twins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really nice
The angle of the picture...my neck hurts from turning it to the left at such an angle.....
Unread 15-02-2013, 02:08
FRC #2429
how does this not break rule G23-1 a ?http://frc-manual.usfirst.org/Updates/0#term 37
Unread 15-02-2013, 02:24
Domtech's Avatar
I Do Everything
AKA: Dominic
Its less than 50 inches from the extended claws to the top of the shooter. I know for sure that it could fit it in the specified 54in diameter cylinder without issue.
Unread 15-02-2013, 02:28
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Should be ~34" horizontally from the second level to the corner, leaving them with 20" of robot outside the pyramid. Looks like the shooter is at an angle so that when it climbs its near vertical so it doesn't add to it, so just looking at the floor from the corner of the pyramid to the far end of the robot as long as thats under 20" which it looks like its possible, then they're fine.
Or I could have just done my geometry completely wrong, it is almost 3am. And it would help if this image wasn't at a ridiculous angle.
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 15-02-2013, 02:41
FRC #2429
i think your math is off considering the first horazontal bar should be at 30in and also if you look at the first diagram it looks like they would measure it from your drive base upwards as your cylinder
Unread 15-02-2013, 02:43
AKA: Brandon Liatys
Rookie Year: 2007
30in in height not 30in from the corner. The cylinder is not relative to drive base. Its not relative to anything, its as long as you can squeeze your robot in. I measured relative to the ground because I'm not there in person with a tape measure, but it looks like even using it relative to the ground it *could* work.
Unread 15-02-2013, 02:49
FRC #2429
thanks for the clarification
Domtech's Avatar
I Do Everything
AKA: Dominic
Under the clarification given in this blog post, it is legal.
If you can put any 54” right cylinder with a height of 84” around the robot, in any orientation, at any moment while it is climbing, and no part of the robot is more than 54” away from the base of the pyramid, your robot does not violate the new rules.
The cylinder is not measured relative to the ground.
