Re: 4 Wheel Drive Too Much Traction
I think we're going to see alot of robots with this approximate design (chute with indexer, dropping into a linear shooter at a ~30deg angle).
This particular robot seems much heavier than it needs to be though... Why two gearboxes to a side unless you were putting mecanums on it? The whole chassis appears to be steel tube and bent sheet steel, which, might be more viable this year than ever before, with the reduced perimeter, but still. Last edited by Racer26 : 15-02-2013 at 09:24. Reason: fixing unmatched parenthesis |
For the robot pictured, if you make the following simplifying assumptions: 1) all four wheels identical and driven independently with the same torque... then the analysis becomes straightforward: http://www.chiefdelphi.com/forums/sh...ad.php?t=99089 JesseK's advice is good though: Quote:
6 wheel dropped center drive
Or you can switch the back or front to omins which is what we did rookie season and it worked wonderfully. And a photo would help ![]() |
Running through the JVN calculator, your current drive train has an overall reduction of 4.67:1. It yields a top speed of 24.13 ft/sec. You need to at least twice that amount of reduction.
My I suggest swapping out the belt drive to chain with the following sprockets. 12 tooth on the transmissions and a 30 tooth on the wheels. That will increase your reduction to 11.67:1, drop your top speed to 9.65 ft./sec, and give you enough torque to turn. The sprockets you want are available from both AndyMarh and VexPro. Last edited by billbo911 : 15-02-2013 at 13:42. Reason: Fat fingers. Thanks Ether! |
They're also likely to have chain and sprockets around from years passed. They may not have other wheel options and moving gearboxes or CoM around is a ton of work. |
I assumed the Center of Mass was at the Center of Geometry of the wheelsUsing Billbo911's 11.7:1 gear ratio, I calculated ~180 oz-in torque required at each motor. |
#10
Replacing the belt pulley on the gearbox with a 12-16T pulley has the same net effect (the robot turns) at potentially less expense -- time & money wise. |
#11
It also requires a different tooth count on the belt, all other things being equal. The flexibility of chain is a great asset here.
#12
They could also slide the gearboxes more towards the center, so long as they're not welded to the frame (can't really tell from the picture if the glare is a weld joint or not). It doesn't look like the two gearboxes on the side will interfere, but it's best to judge it hands-on.
#13
We solved the problem by using free spinning low traction wheels in the front and doubling up the motors in the back for more drive power. Although the robot still struggles to turn sometimes, it is a noticeable improvement to before. We can even turn in one spot. Thanks for the help everyone!
#14
As a quick fix, i'd recommend putting all four motors on the rear wheels and swapping the fronts for omnis - just a shaft, no gearbox.
its hard to tweak four independent motors and gearboxes, especially without encoders etc. and definetly you need to gear down to about 11-12 fps max, maybe sprockets? |
#15
Instead of being offended by your tone, I think I'll build on your point. Jesse's post will lead you to determining the root cause of the problem. It will teach you how to analyze a drivetrain and design it better in the future. That said, the solution it would lead you to at this point in the season would be impracticable to implement. It is correct, but not necessarily an optimal solution for your current situation. You really should learn to use the analyses tools he is giving for future designs. In the mean time, what I gave you will get you going in the shortest amount of time and least amount effort, something that is needed with the amount of time you have left. And, if you apply the information I gave you to Jesse's approach, you will see that it works, too. Please give it a try once you get the drive working to your satisfaction. |
