Go to Post You don't need to be on a team to be involved with FIRST. - Koko Ed [more]
Unread 15-02-2013, 13:07
ohhs4284 ohhs4284 is offline
FRC #4284
ohhs4284 is an unknown quantity at this point
How to wire a Vex Spike
My team is using a Vex Spike connected to a window motor. I understand the motor-side wiring and the PWMs. However, how do I wire the battery side? Do I plug into the PD board, if so what gauge do I use? Do I need a breaker in the board, if so what ampage? Thanks.
Unread 15-02-2013, 13:19
mschwab013's Avatar
mschwab013 mschwab013 is offline
AKA: Matt Schwabenbauer
FRC #0291
mschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to all
Re: How to wire a Vex Spike
When using a spike, I always plug it into the PD board using 12 gauge wire and a 40 amp breaker. I hope that helps!
2013 Pittsburgh- Gracious Professionalism award, 7th seed, 6th alliance captian, quarter-finalist(291,3492,4601)
2013 Queen CIty- Chairman's Award, 39th seed
2012 Pittsburgh- 23rd seed
2012 Buckeye- 34th seed, 2nd alliance, quarter-finalist(291,1241,4085)
2011 Pittsburgh- 13th seed, 5th alliance, quarter-finalist(291,337,3504)
2011 Buckeye- 18th seed, 8th alliance, quarter-finalist(279,291,3496)
2010 Finger Lakes- 15th seed, 5th alliance, quarter-finalist(291,1507,1559)
2010 Buckeye- Chairman's Award, Imagery Award, Quality Award, 4th seed, 1st pick, 1st alliance, semi-finalist(291,1014,1629)
Unread 15-02-2013, 13:27
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Per R47, you must connect it to the PDB with a 20 amp breaker. Per R48, you must use 18 AWG minimum wire.
This violates R47.
