Go to Post Build season can't come soon enough. - Ryan Dognaux [more]
Unread 15-02-2013, 16:41
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
Ammeter
Does anyone know if an ammeter in line between a Victor and the PD board is legal? Please respond ASAP.
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 15-02-2013, 16:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Ammeter
Originally Posted by R54
Custom circuits shall not directly alter the power pathways between the ROBOT battery, PD Board, motor controllers, relays, motors, or other elements of the ROBOT control system (including the power pathways to other sensors or circuits). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, if the effect on the ROBOT outputs is inconsequential.
So yes, a low-impedance current sensor is legal. Make sure it can handle the number of amps you could be throwing at it. CIMs can briefly draw around 100 amps under stall.
Unread 17-02-2013, 02:16
jmiller18 jmiller18 is offline
FRC #2429
jmiller18 is an unknown quantity at this point
Re: Ammeter
Another possibility is a current clamp. It a loop that wraps around the insulated wire and measures the current without touching the filaments so it doesn't alter the pathway to motor, but a low impedance ammeter would work, or CAN can tell u the output current of a jaguar
