Go to Post I believe it is in the spirit of the game is to score more points than your opponent within the rules. That means offense AND defense. - Gary Dillard [more]
Unread 15-02-2013, 18:03
justinkgoh justinkgoh is offline
FRC #4638
justinkgoh is an unknown quantity at this point
Where to connect Solenoid Breakout power cable to?
How do we power the solenoid breakout. I know that we connect it to the positive and negative inputs and outputs on the breakout, but where and how do we connect it to the PD?
Unread 15-02-2013, 18:05
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: Where to connect Solenoid Breakout power cable to?
Are you using 12v or 24v solenoids?
12v it gets plugged into a 20 amp breaker on any of the slots.
24v it gets plugged into the cRIO power port.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 16-02-2013, 10:02
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
I am little confuse who to connect to control solenoids, the 3 double 12 V to control solenoids, we use C++ Crio II , NI 9472 module, I connect 12 V solenoids by The spike each which should be connected to a PWM output of the Digital Sidecar and powered from the Power Distribution Board. So I need 6 Spikes. Is it right. May be there is anther way??
I read his http://www.chiefdelphi.com/forums/sh...d.php?t=112088
Solenoids can be powered via a Spike, or the breakout. Only 24volt solenoids have to be powered via the breakout as you cannot supply 24 volts to a Spike.
http://team358.org/files/programming...ataDiagram.pdf
And
http://wpilib.screenstepslive.com/s/...dware-overview
The Solenoid Breakout Board takes the Digital Outputs of the NI 9472 module and converts them into a form more readily usable by FRC teams. The Solenoid breakout board accepts 12V or 24V input power and provides a signal and ground output for each of the 8 output channels. The Solenoid Breakout Board should be plugged into the NI 9472 module and plugged into the Power Distribution Board.
TEAM 1946-Tamra
Unread 16-02-2013, 10:10
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
In that case you could use spikes, but you can also use the breakout board. I personally would use the breakout board since it doesn't take up the space of 6 spikes.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 10-03-2013, 15:44
GrimmReaper's Avatar
GrimmReaper GrimmReaper is offline
FRC #2046 (Bear Metal)
Rookie Year: 2011
GrimmReaper is on a distinguished road
I was just reading through this thread and wanted to mention it in case anyone happens upon it in the future - if you do need to use spikes as you described, you wouldn't need 6 spikes for 3 double solenoids. For solenoids spikes can operate 2 solenoids each, that's why the relay object has off/forward/reverse/on the on mode does both solenoids... check wiring diagram in figure 2 of the spike user guide for details: http://content.vexrobotics.com/docs/...uide-sep05.pdf
so in your case you could get by with 3 spikes.
hope that helps ;-)
