Go to Post Stop making me want to spend money on books! I don't need any more good influences in my life!!!! - FourPenguins [more]
Unread 15-02-2013, 23:02
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
Rookie Year: 2010
jp1247 is an unknown quantity at this point
VEX Pro Spike Relay half-broken(maybe?)
In a previous post in the pneumatics section, I mentioned that the spike would only turn on (forward + green light) if A+B channels were on, which I realized today isn't correct. The spike, given reverse (red light on the DSC) makes the spike go in reverse. Forward, does nothing, green light on DSC, solid orange on the spike. Both, red+green sets the spike to forward, solid green light, when the light should be out for both on, (12v + 12v).
Same compressor code, relay channel, etc all work with a different VEX Pro spike...
Has anyone else experienced this / have a diagnosis / repair method?
Much appreciated,
Joe Porter
"No, you can't use the Kinect to do pelvic thrusts."
